Honda HX rims on GD?
Old Aug 22, 2011 | 04:10 PM
CalicoJack's Avatar
Stock 14 inch Civic HX rims....
Anyone know if these will fit? I would like to use them at winter snow tire swap rims?
Thanks in advance.
Jack
Old Aug 22, 2011 | 04:11 PM
Bthasht's Avatar
Yes they will fit. Do a search on showcase gd3. He had them on his base. Only problem is offset is so high they get swallowed by the wheelwell.
Old Aug 22, 2011 | 08:53 PM
CalicoJack's Avatar
Thanks. I found him. Looks good enough for me.
Old Aug 22, 2011 | 09:36 PM
Hootie's Avatar
HX.... HX.... Correct me if I'm wrong but aren't they also nicknamed the "Poor Man's ITR Wheel" since they look similar to the wheels on the '96 Integra Type R? (Not talking bad about the wheel, just trying to clarify)
Old Aug 22, 2011 | 09:43 PM
Bthasht's Avatar
^^That is a true statement there. They would look great if the offset was lower. Not to mention the fact you can go super low on 14"
Old Aug 23, 2011 | 05:39 AM
CalicoJack's Avatar
They are ultra light rims so hey will help with gas milage. That is he main reason I'd want them on.
Old Aug 23, 2011 | 07:55 AM
Hootie's Avatar
Ah, I thought so. I've spoken with a member on here that had a set on his BBP GD, he had to use 3mm (I think) spacers to run them so the wheel wouldn't scrape the brake caliper as it rotated.
Old Aug 23, 2011 | 08:52 AM
Bthasht's Avatar
^ correct again. Running a 10mm spacer would make them look alot better as well.
Old Aug 23, 2011 | 10:22 AM
CalicoJack's Avatar
Ok.... Are we saying that I need the spacer to make them fit or make them look better?
Old Aug 23, 2011 | 10:37 AM
Bthasht's Avatar
^ yes you may on the front. No more then 3_5mm
Old Aug 24, 2011 | 10:31 AM
mahout's Avatar
Thanks in advance.
Jack
My stock Honda Civic HX 5.5x14 ALLOY wheels are 45 mm offset and fit very well. They are somewhat lighter than other wheels so when I have used the HX wheels they have been good handlers as well.
ps stock Fit wheels are 52 or 53 mm offset so they widen track by 5/8" or so and do not rub in any circumstances..
Since there have been comments that the offset is very high I went and checked them; the offset is 45 mm and they DO NOT sink back into the wheel well.
Old Aug 24, 2011 | 10:38 AM
mahout's Avatar
No. 45 mm is actually the best offset for Fit. see my reply other.
Old Aug 24, 2011 | 11:55 AM
CalicoJack's Avatar
Thanks for all the replies. I guess I need to get off my ass and get some tires on them and try them out.
EMC2
Oct 31, 2012 10:47 AM
unphit
Feb 20, 2008 10:45 PM
Quartz
Dec 9, 2007 03:55 PM
realjazz
Dec 1, 2006 01:29 AM
nate9
Feb 20, 2006 03:35 AM
