MAF Question
Old Sep 12, 2011 | 11:48 PM
plantsrights's Avatar
MAF Question
Couldn't find this with search...
Does anyone know if it is possible to (plug & play) swap in a larger MAF from a Pilot or a Ridgeline or a Civic Si? Or would you still need to run a tune?
The goal would be to run the largest possible charge tube before the TB on a SRI or CAI...
Thanks.
Old Sep 25, 2011 | 11:21 PM
myblackhatch's Avatar
Thanks.
You would need to calibrate the new maf sensor inside the ecu but it wouldn't make a difference because when you are running at wot your ecu should be switching over to speed density and running off of the map sensor. Really all the maf is there for is idle and steady driving. Hope this helps.
Myxalplyx
42
Apr 29, 2016 04:38 PM
cdninsw
Feb 20, 2014 05:33 AM
Gary Dyrkacz
Jul 10, 2013 09:11 AM
explosivpotato
35
Aug 15, 2009 02:57 AM
Fitinside
Mar 26, 2007 09:54 PM
