No audio output when it rains
Old Oct 5, 2011 | 03:00 AM
madtodaimax's Avatar
Ive got a 2008 Fit that I just got used. The original owner put in an aftermarket pioneer HU and speakers. i just noticed that there is no audio output when it rains. Same thing happened after I wash my car. The head unit still has power and sometimes I hear a "pop" through the speakers before the audio cuts off. I assume there is a ground or short somewhere and the HU is going into safe mode to protect itself. Any ideas on where I should start looking to solve this problem?
Old Oct 6, 2011 | 11:30 AM
pouncer11's Avatar
Sounds like the negative on the speakers is grounding to the chassis. Try taking off the door panels and making sure all of the wires are properly connected and covered. If they are then try installing some washers or butyl between the speaker and the door frame. New screws would also help.
Old Oct 8, 2011 | 03:53 PM
Thanks for the reply. Pulled off the doorpanels and looks like the previous owner used a long self tapping screw and drilled the speaker through the mount and into the door itself, causing it to ground out.
kmschwem
Feb 16, 2020 03:59 AM
tleger88
Apr 11, 2014 02:11 AM
tleger88
Jan 19, 2014 10:51 AM
FITment
Dec 28, 2010 10:11 AM
Mervby
Jan 16, 2007 07:54 PM
