Noticeable tailpipe vibration?
Old Oct 12, 2011 | 12:14 PM
GVlog's Avatar
Does anyone notice significant and audible tailpipe vibration when they start-up their Fit Sports in the morning and let it idle? Mine seems to have been doing that for a couple of days. It's been colder than usual but the nights have only dropped to 40-50 degrees F here in the San Francisco Bay Area.
The vibration seems to disappear after less than half a mile of driving. I haven't noticed it when I start-up the car during the middle of the day.
My Fit is an automatic and, being a Sport, it has the chrome exhaust finisher.
Old Oct 12, 2011 | 12:48 PM
neil patrick harris's Avatar
i don't get any vibration. well, it does vibrate but doesn't shake noticeably at all and it's not something that's audible. is yours rattling?
Old Oct 12, 2011 | 12:53 PM
nickemangione's Avatar
maybe just a loose screw for the finisher?
Old Oct 12, 2011 | 12:57 PM
GVlog's Avatar
It's somewhere between a rattle and vibration. It doesn't quite sound like the tailpipe if hitting against something. It's more like the tailpipe vibrates enough that I notice it when the car is all quiet.
The tailpipe and the finisher seem to be reasonably secure. No loose movement from either.
I should explain that the vibration is more felt and heard rather than seen. I don't see the tailpipe itself moving.
Old Oct 12, 2011 | 01:00 PM
GVlog's Avatar
I'll investigate that tonight when I get home.
Old Oct 12, 2011 | 01:02 PM
let us know!
Old Oct 12, 2011 | 01:03 PM
mhadden's Avatar
Heatshield....
Old Oct 12, 2011 | 01:09 PM
Originally Posted by mhadden
Heatshield....
true...
sometimes when your in the car you cant really tell what direction the noise is coming from
Old Oct 12, 2011 | 02:19 PM
Honda neewb's Avatar
Here is a rediculous solution, get aftermarket exhaust. Huge mm tip wel make it better, our maybe worse. I don't know...
Old Oct 12, 2011 | 03:16 PM
GVlog's Avatar
true...
Would that sort of rattle go away after a short warm-up?
Is there a simple way to check if it is the heatshield? Could I just press on it with an object and listen if the rattle goes away?
Old Oct 12, 2011 | 03:50 PM
Goobers's Avatar
And we're sure this isn't like the other threads about rattle noise coming from inside the hatch area? Like a loose scissor jack or something.
If something is sensitive to vibration, the car should be vibrating a little harder at the first start up of the day, as it's the coldest and roughest time for the engine, causing more pronounced vibrations. Those vibrations can travel around the car. Once it warms up, it won't shake as hard.
Old Oct 12, 2011 | 04:59 PM
Virtual's Avatar
I bet that all is normal.
At startup, the idle speed is higher when the temps are colder outside and it will be a bit rougher and louder.
Old Oct 13, 2011 | 07:42 AM
xSimply's Avatar
A little vibration doesn't seem too outta place from a small four cylinder, but if it's that
noticeable it may not be normal. Does the rattle/vibration change or go away if the
engine revs increase?
Old Oct 16, 2011 | 08:39 PM
My_Little_Toaster's Avatar
Mine does the same in the morning. About 60 degrees outside. You can see the muffler vibrate atleast 1 inch side to side. To me its normal, cause of the rubber mounts and no flex pipe.
Old Oct 24, 2011 | 01:47 PM
GVlog's Avatar
O-o-o-o-o-o-okay. I found the problem.
I had secured my rear license plate with just the two top bolts. I added two bolts to the bottom of the license plate and the noise is now completely gone.
And there is no "embarassed" emoticon to express how I feel.
Old Oct 24, 2011 | 01:57 PM
Don't worry about it man...when you have a new vehicle every little noise is an issue....I know that I won't sleep until I track it down...
Glad to hear it was a simple fix though!
Old Oct 24, 2011 | 04:18 PM
mhadden's Avatar
Ha! I had this same thing happen to me, but I thought the back hatch developed a rattle (not the exhaust). It's amazing how the hatch amplifies the sound from the license plate...I put some rubber bumpers on the license plate (like those on the back of cabinet drawers/cupboards) to avoid the plate smacking on the hatch.
gkitf16
Apr 16, 2019 06:41 PM
laughter95
Aug 20, 2017 08:25 AM
PhaseShiftDown
Oct 19, 2014 03:33 PM
The Critic
Apr 20, 2012 04:30 PM
Alex Rodriguez
May 4, 2005 11:16 AM
