Condenser grill
Old Oct 18, 2011 | 02:50 PM
littleblackcar's Avatar
Condenser grill
Is plastic mesh strong enough to use as a DIY a/c condenser grill?
Old Oct 18, 2011 | 04:44 PM
that's too general. do you have reference pictures and what is the material (other then just "plastic")
Old Oct 18, 2011 | 04:50 PM
It would be something like this:
McMaster-Carr
Old Oct 18, 2011 | 05:04 PM
hummm... that might work..would that impede the radiator not getting enough air at speed?
i thought you were looking at a much bigger hole size... and thicker material so it doenst flap around...
Old Oct 18, 2011 | 05:18 PM
mesh size
People have used plastic mesh with small enough holes to keep out rocks; they've also used gutter guard and wire mesh. I'm just wondering if something like plastic mesh or plastic gutter guard is strong enough to stop a rock. Plastic would be a lot easier to work with than metal! I bought some aluminum gutter guard, but I'd actually rather find something more pliable.
Old Oct 18, 2011 | 09:47 PM
Goobers's Avatar
You can try some mesh from chicken wire... very thin, 22 gauge (I think) wires, with 1/4 inch sized holes.
I bought a fairly long roll, cut a strip about almost two inches wider than the opening, then tied it to the lower grille. Because the roll was pretty tightly wound, it had a pretty good curvature that I mostly kept when tying it down.
I didn't flatten it, because I'm thinking/hoping that the curved nature would allow it to flex a little when hit by a larger fast moving rock, absorbing most of the impact, instead of pulling on the tied down spots (which were the clips for the grill, pretty weak)
Old Oct 18, 2011 | 11:08 PM
Paul56's Avatar
Old Oct 18, 2011 | 11:30 PM
vinnymac's Avatar
Or something more sturdy that protects and has a good air flow.
Like this and just cut custom fab it to fit your grill space.
Old Oct 19, 2011 | 08:51 AM
Originally Posted by Paul56
That looks good---what did you use?
Old Oct 19, 2011 | 04:16 PM
Paul56's Avatar
Bought this...
SES Trims® - Chrome Billet Grille - 2011 Honda Fit Grille - SES Trims SES-CG210
...and bolted it on.
I'm sure it mildly impedes airflow but I've had no overheating issues
with many 100+ degree days here in Texas this summer.
Old Oct 19, 2011 | 06:22 PM
Was drilling involved? :-)
Old Oct 19, 2011 | 10:16 PM
Paul56's Avatar
No drilling.
The unit comes with 4 bolt studs... a pair on either
end of the unit.
Those bolt studs slide through the plastic slats in the
lower grill with a plate fitting over from the inside and
bolts to hold it on
You need to remove the rad shroud to provide access
to complete the install.
Old Oct 20, 2011 | 09:47 AM
That sounds perfect! I'd have to paint it black, though....
Old Oct 20, 2011 | 04:00 PM
Paul56's Avatar
...either that or get it powder coated black.
I installed mine early in the spring... still happy with it.
Old Oct 25, 2011 | 10:03 PM
Did it!
I finally rigged up a grill! I used metal gutter guard, spray-painted it black, and zip-tied it in. All I took off was the upper grill cover (not the grill), and did it all by reaching down to the front of the lower bumper. Puncture wounds galore, but I got it done!
over40pirate
Jul 7, 2013 04:09 AM
MeTaLoFeArTh
Apr 17, 2012 07:50 PM
Malice101
Feb 5, 2012 12:11 AM
Spacecoast
Oct 8, 2009 10:35 PM
Spacecoast
Sep 29, 2009 04:23 PM
