Can anyone tell me what part this is?
I need help identifying a part on my front pasenger door. It's the round black rubber plug that sits at the top left hand corner of the door. It is right between the panel and the door hinge (right next to the rubberstrip on the door).
Hole where the black plug should go into. Does anyone know the part name and number?
This is the part that I need. The round black plug. What is it called?
That might be #29 (p/n 95551-25000)
You can search the diagrams on this site and try to find it: OEM Honda Parts & Honda Accessories - Bernardi Honda Parts and Accessories
Look up your car > select the "Body/Air conditioning" section > select the "FRONT DOOR GLASS - DOOR REGULATOR" subsection. That's the best diagram I found, good luck.
Looks like a hole plug...
Doesn't have to be a Honda part#. Look around auto parts store or hardware store. As long as its the same size, should work. Take out the other side and bring it with you. That's what I would do unless you're OCD about it being a Honda part.
Ansl1,
It looks like the part in question is the 25MM "Blind Plug", as Honda officially calls it. The OEM p/n is 95551-25000 and it's about $2 at hondapartseast.com
Hope this helps!
Hope this helps!
splinters81
Jun 16, 2024 02:12 PM
msoulier
Jul 13, 2011 12:31 PM
Jazz GD3
Jul 23, 2009 10:25 PM
