Check Engine light is on
Old Nov 6, 2011 | 08:00 PM
peacemaker1911's Avatar
This morning my check engine light appeared on my 2008 Fit.
It has 65k miles and well maintained at Honda dealership. I was going to take it in tomorrow to change oil because it was on 10% but the light came on today so I went to jiffy lube to change it. Engine light is still on, and coded
Definition:
* VTEC Oil pressure swith circuit low voltage
Probable Cause
* Check Oil level and pressure
* Open or Short circuit condition
* Failed VTEC Pressure Switch
I got these at AutoZone cause dealership was closed.
My question is, whats do they mean and do they sound expensive????
Old Nov 7, 2011 | 01:22 PM
Dealer said $390 to fix. He would not give me any details to whar part it was other than " P2647 Faulty VTEC Solenoid / switch assembly" Is he ordering the whole assembly or just the switch?
He said the thing switch was stuck on the "ON" position.
Switch
Assembly
Old Nov 7, 2011 | 01:32 PM
malraux's Avatar
Did they run through the diagnostics or just tell you that based on the code?
Old Nov 7, 2011 | 02:02 PM
Based on the code I guess. They put it in the stall, and hooked up the computer, thats it.
I can get the switch from $15-$55, removing and replacing dont look hard. Now the assembly I would probably let them do.
Old Nov 7, 2011 | 02:18 PM
Steve244's Avatar
If it were me, I'd clear the code and see if it came back before having it fixed. Might be a transient that won't repeat.
edit: although "stuck on the on position" doesn't sound transient.
Old Nov 8, 2011 | 01:21 PM
wistlo's Avatar
good way to read/clear codes
If you need to clear the codes, don't have a reader, and have an Android smartphone, this is a good combination:
Android app: Torque — OBD2 Performance and Diagnostics for your Vehicle
OBD-II Bluetooth interface: Amazon.com: PLX Devices Kiwi Bluetooth: Automotive
You can read the OBD data in real time and and upload to a server, as well.
Old Nov 8, 2011 | 01:45 PM
malraux's Avatar
Glancing at the service manual for that DTC, it could be either the switch or the whole assembly. It depends on what the computer told them.
Old Nov 22, 2011 | 02:38 PM
Where is the unit located ? I cannot see it anywhere.
Old Jan 16, 2012 | 06:05 PM
Everyone was saying it was on the passengers side, but it ened up being on the drivers side of the block. Took about 5 minutes to change the part and about $75 for the part including the o-ring. took about half a day for my light to come off. VTEC KICKED IN YO!!!!
Old Jan 16, 2012 | 06:46 PM
Krimson_Cardnal's Avatar
+++bingo+++
Old Jan 21, 2012 | 05:20 PM
clemsonteg's Avatar
Good info to have, always comes in handy if it happens to you
Old Jan 21, 2012 | 05:58 PM
einstein77's Avatar
Too bad Honda charges so much for such a fix, but that's their life blood.
mattpuchlerz
30
May 12, 2017 03:31 PM
Number18
Dec 4, 2015 01:26 AM
oldblue
Jun 13, 2014 07:39 PM
Skytraveler
Jun 25, 2010 09:03 AM
Randy Brick MacKenna
May 9, 2005 01:49 PM
