Rubber window trims sticking to window
Old Dec 16, 2011 | 07:05 AM
hashgroover's Avatar
I recently had a problem with my Rubber trims sticking to my windows , causing the rubber trim to wedge.
I would just like to share the best solution, which I surprised and found it very practical.
Of course nothing beats silicone spray, but this one again is very practical and economical.
From my research I found out that Talcum powder will do the job. Glass slides best on rubber when treated with talcum powder. I also found out that the rubber trims work best when they are clean and dry.
Hope this will help you guys
Old Dec 16, 2011 | 02:19 PM
mhadden's Avatar
Use some silicone spray, available at most auto stores.
Old Dec 29, 2011 | 04:01 PM
tw07gd3's Avatar
silicon spray can be detrimental to rubber so try shin etsu grease which is made specifically for gaskets and seals
Old Jan 6, 2012 | 09:01 PM
jdm_94's Avatar
I know Honda sell a product just for this, why you don't call your local dealer to see if they are still selling the product.
Old Jan 8, 2012 | 01:58 PM
andre181's Avatar
I had this problem last summer, so bad that my drivers window wouldn't roll back up without some physical assistance by me pushing it up.
Do not use silicone spray/lubricant! I did and it caused the rubber to begin to crack and slowly disintegrated.
Honda replaced the rubber window track under warranty for me. So far no problems!
Old Mar 19, 2012 | 01:59 AM
b0li's Avatar
Hello
I have the same problem. I bought my 07 Fit in may 2011 and previous owner had front windows tinted. In february 2012 I went on MOT and dude there sad that is prohibited in Slovenia to have front windows tinted and I had to pull down the gray foil. Of course, mounting adhesive stayed on and the windows are all sticky when is hot outside.
I found that nail polish remover will clean off the adhesive.
The problem is how to get under (behind) the rubber trims at the bottom of the window, can I remove the rubber trims somehow.
I pulled them up, but I was afraid to brake something if I pulled to much.
I searched the internet but I didn't know if this (rubber trim) is the right name of the thing. I didn't find anything useful.
Can anyone offer some solution to properly remove the strip of rubber at the bottom of front driver`s window?
This is how it looks:
This black strip of plastic/rubber I want removed:
Thanks for helping me.
_________________________________
Addition:
I had to take off the door panels to clean sticky adhesive. Now is everything perfect.
If anyone is going to need this information....
Old Apr 3, 2012 | 09:47 PM
Dean's Avatar
As mentioned above, this is what Honda uses to lubricate rubber door trim and sunroof seals.
It only takes a very small amount and you rub it in with your fingers. I have been using this tube since I bought it for the sunroof seals on my '99 EPB Honda Civic Si.
runbikerun
Apr 17, 2023 08:57 AM
Press Fit
Jan 9, 2017 07:01 PM
patm95
Jun 22, 2016 11:36 AM
taco
Apr 18, 2012 02:56 PM
gar1013
Jan 20, 2008 11:06 PM
