Show me your Map Lights
Old Dec 30, 2011 | 06:03 PM
billboard's Avatar
Found a few threads mentioning this subject, but not a lot of pictures...
So, Please if you installed Maplights in your Fit (oem/jdm/retro-fit/etc) please post pix and tell me what model of honda/acura/or other vehicle that you got them from.......
any help and pix greatly appreciated...
Old Jan 8, 2012 | 06:57 PM
billboard's Avatar
i plan to install these DA map lights soon
Old Jan 24, 2012 | 12:33 AM
billboard's Avatar
installed Map lights that i got from an Element at the junkyard today, pain in the ass dealing with the junkyards with the newer vehicles (im fairly certain they think the beat up, snow soaked, haggard, possibly not working parts are made of solid gold)...
Element map lights same as JDM ones...
http://www.icbmotorsport.com/jdmfitgd3map.html
anyways
made a custom bracket as there is no place to mount the Map Lights, which you would think there is since these map lights supposedly come stock in Fits in Japan, anyways after researching a bit- I didn't find any real easy/clear way to mount them up.... so here is what i came up with...
clean junkyard lights up...
make a template
cut a hole- make sure not to measure anything- measuring is for pussys...
run a wire from dome light to map lights with a hanger... wire up plug (thats the nice part about getting one from the junkyard no need to solder wires to map lights- you get the plug)
this fine ass piece of engineering... mounts to where the rear view mirror is "was"
had to trim up the foam piece that was there previously so ^the above could mount to rear view mirror location... (once you do or have done this mod- you will know what foam piece im talking about)
put trimmed blocks back up
install everything
hope this helps someone out- it was a very long process for me, lot of installing, un-installing- cutting, measuring etc...
Old Jan 24, 2012 | 09:07 AM
Blkfitsprt's Avatar
Nice job. The fit sure does need map lights. I will have to consider paying a visit to the wrecking yard.
Chris
Old Jan 24, 2012 | 10:51 AM
Jamy's Avatar
You can order the OEM map lights from CFL for like $30. Uses oem mounting which is already there and wiring is just done by soldering a wire from the power wire of the dome light.
Old Jan 24, 2012 | 12:41 PM
FitStir's Avatar
My post from this thread ---> https://www.fitfreak.net/forums/2nd-...ort-w-nav.html
Originally Posted by FitStir
Here's the pics:
You can see the pieces of wood I cut. I decided the 2" height was a little too much, so I recut them at 1 3/4".
I also gave them a slight taper from 1 3/4" to 1 5/8" to form to the angle between the roof and the headliner. It really wasn't necessary, but I wanted it as flush as possible.
In order to minimize the "drop" in height of the roof liner I had to snap off the 2 tabs that helped secure the original map light (seen bent out on previous pics). I tried to fit them between the map light & console (similiar location to where they were on the existing map light), but they're too long and push the console further down. Here they are on top of the piece of roof liner that was cut out.
Here's the finished install.
and a wider shot.
As I mentioned in my previous post the mounting/grounding bolts are slightly short. I still haven't got the longer ones, but I will soon to correct the slight crease toward the front by the maplight, might add a spacer depending on the fit.
As it is now it's extremely secure even though I didn't secure the sunglass section to the roof, and it's still flush. After I get the longer bolts, I will attach some velcro or double stick tape to the back of the sunglass holder part to be more secure to the roof. I don't want anything permanent cause they will have to move the console forward whenever I get the sunroof installed.
Old Jan 24, 2012 | 01:36 PM
billboard's Avatar
There is no OEM mounting in GD.... Right?
Old Jan 24, 2012 | 01:42 PM
Jodele's Avatar
I've got the one in the cealing and two in the bottom of the mirror...
Old Jan 24, 2012 | 01:59 PM
Jamy's Avatar
Hmmmmm I'm not sure about that.
Old Jan 24, 2012 | 02:23 PM
billboard's Avatar
im pretty positive there is no where to mount maplights in GD, i didnt see any when i cut a hole anyways...
Old Jan 24, 2012 | 02:30 PM
Jamy's Avatar
Ah well then disregard that for GD applications. Did the GD not have a map lights option? That would be the only reason I could think of for it not having the mounting spots.
Old Jan 24, 2012 | 02:43 PM
billboard's Avatar
thats what i was thinking, but they advertise these maplights as JDM option for an 07+ GD fit....
but im thinking it is a lie, it doesnt make sense to me that the mounting points dont exist...
JDM Fit GD3 Map Lights
Old Jan 24, 2012 | 05:28 PM
Cocowheat's Avatar
wait what? there are fits that come with no map lights?
edit. ahh never mind i just realize you guys were talking about the GD.
radioarno
Aug 31, 2023 10:41 AM
bfeinzimer
Dec 26, 2009 07:58 AM
Benggolf
17
Aug 5, 2009 01:23 AM
kevvur
20
Dec 6, 2008 03:29 PM
copilot18
Feb 13, 2008 02:15 AM
