07 toyota yaris 14" steel rim
Old Jan 7, 2012 | 03:04 PM
helphelp911's Avatar
Hi, will 07 toyota yaris 14" steel rim fit my 07 fit? thanks!!
Old Jan 7, 2012 | 03:52 PM
MNfit's Avatar
is the bolt patter 4x100?
Old Jan 7, 2012 | 05:17 PM
Scala's Avatar
im pretty sure, yaris has 4x100 bolt pattern. make sure you check
Old Jan 7, 2012 | 09:39 PM
yes, they are 4x100.. so it is ok for my fit??
Old Jan 7, 2012 | 09:43 PM
Scala's Avatar
Yes sir, don't get anything less than 14" it won't fit with the disk break
Old Jan 9, 2012 | 12:31 PM
oh no..i bought the 07 toyota yaris wheel.. and install it on the driver front side. Whenever i brake, i heard some click noise. i think the wheel is hitting on the brake. also, when i drove on rough road, i heard some noise coming from the wheel.. is there any way to fix it?
thanks
Old Jan 9, 2012 | 06:40 PM
dstock1088's Avatar
I didn't think the yaris came with 14" wheels. I work at a dealership and I do believe they are 15's.
Also if you replaced one wheel with a 14"? Aren't fit wheels 15"?
I drive a sport with the alloys so maybe the steel wheels are different.
Old Jan 9, 2012 | 07:37 PM
feared's Avatar
you might need a spacer for clearance
Old Jan 9, 2012 | 08:22 PM
solbrothers's Avatar
I've fit 14's on my fit. you might need a spacer if it's rubbing the face. take the wheel off and check if there's any paint missing from the inside of the barrel/back of the face. You could also shave the caliper
Old Jan 9, 2012 | 09:18 PM
thanks, i will try a spacer.. one simple question.. if i use spacer on one wheel.. do i need it for all others wheel too??? thanks
Old Jan 9, 2012 | 10:16 PM
if you're going to use a spacer on a front wheel, you should use it on the other front wheel as well.
GoJaskill
Dec 22, 2018 07:29 AM
tommyarmour
Mar 10, 2016 01:45 PM
ESMWheels
Sep 28, 2011 01:10 AM
yasirfaheem
Aug 17, 2010 01:42 AM
LuxuryFit
Dec 26, 2007 10:05 PM
