Civic Si Exhaust on 2012 Sport?
Old Jan 9, 2012 | 10:13 AM
StinklePink's Avatar
I'm looking to do an inexpensive, low modification upgrade to my stock 2012 Sport exhaust. Was wondering if I can find a Civic Si exhaust in a jun yard an bolt it up straight on to my car. If necessary, have it brough to a muffler shop for a quick install/mod?
Anyone know if this is doable? If I got just a Civic Si muffler, is a direct bolt-on? Anyone do this yet? Got a sound clip and/or picture?
Old Jan 9, 2012 | 12:28 PM
JDMchris.com's Avatar
I run THIS
technically you can bolt it up... will it fit correctly? NO. The rear sections from the civic and the FIT are extremely different.
Old Jan 9, 2012 | 12:49 PM
Just a muffler?
OK thanks.
So next question.....If I bought a decent Civic Si muffler from a junk yard, could I have my existing muffler cut off an this new muffler welded on? Are the tubing sizes compatible? Could a fairly competent muffler shop pull this off?
Old Jan 9, 2012 | 01:09 PM
GAFIT's Avatar
A competent shop could install the muffler even if it is a different pipe diameter. My question is why? You won't see a power increase and if you're looking for a visual or sound gain, you'd be better off buying a cheap aftermarket muffler and having a shop weld it on.
Old Jan 9, 2012 | 01:16 PM
Yes...going for a little better sound without getting something obnoxious. I figured I'd be able to pull that off with a well made OEM Si exhaust (read:muffler) from a junker, at 1/2 the cost of a questionable maybe crappy after-market exhaust.
The Si exhaust sounds and looks good and the Honda OEM stuff is generally well made and durable.
Old Jan 9, 2012 | 01:23 PM
GAFIT's Avatar
I agree. I'm just not sure that the good sound isn't created by the high hp K20 and not the muffler.
That being said, I think it would be a simple job to a muffler shop. I once bought a Dynomax cat back kit for a hatch and had it installed on my Civic sedan. The muffler shop just had to make a couple cuts, weld in a small section, and re-weld. They charged me $40 cash to do it and it worked great.
Old Jan 9, 2012 | 01:28 PM
Good point!
Old Jan 9, 2012 | 01:29 PM
EP3 mufflers used to be a common mod (well, commonish) on GD3's when I first joined up.
Honda Fit GD3 EP3 axleback - YouTube
Chitown Fit
Nov 18, 2018 07:18 PM
BMW ALPINA
22
Jul 27, 2018 11:50 PM
Allyoopski
Nov 10, 2016 08:17 PM
Saved
75
Oct 12, 2011 02:09 PM
Sean
May 4, 2005 04:44 PM
