Question For The Exhaust Gurus.
Old Nov 14, 2018 | 10:43 PM
Chitown Fit's Avatar
Question Question For The Exhaust Gurus.
Will an Si Muffler fit on a Gen 3?
Old Nov 15, 2018 | 08:59 AM
Not without modification.
Old Nov 15, 2018 | 11:41 AM
2Rismo2's Avatar
With enough money, you can make almost any exhaust fit.
Is there a particular reason why you want that specific exhaust to fit a GK?
Old Nov 15, 2018 | 02:07 PM
bill bosco's Avatar
the tanabe medallian exhast is a nice dual outlet unit , let me guess , you've gotten a hold of an si muffler ? would be alot of work , not alot of space under there .
the stock muffler is pretty compact
Old Nov 15, 2018 | 02:18 PM
evilchargerfan's Avatar
one guy pulled it off
(I believe it involves customization)
Old Nov 15, 2018 | 03:11 PM
Thanks for the responses. I'm going to pass on the Si Muffler. I'll take a look at Flowmaster and Borla.
Old Nov 15, 2018 | 03:43 PM
Old Nov 16, 2018 | 11:53 AM
bill bosco's Avatar
https://www.youtube.com/watch?v=pXoRUeC4Gik
i like the catted RV6 alot but it doesn't seem like it'll be ca. or n.y. legal . i'm in n.y.
Old Nov 16, 2018 | 10:06 PM
ThadCastle's Avatar
Shouldn't have a problem in NY. Just to be safe, you can run an oxygen sensor spacer. I've used these with test pipes (no cat at all) and never had an issue on any of my cars in the last 10 years.
Old Nov 17, 2018 | 07:04 AM
bill bosco's Avatar
wouldn't set off a code ? i have to look into this
Old Nov 17, 2018 | 08:43 AM
Even if it doesn't set off a code, if you're caught you're committing a federal offense with massive penalties.
Old Nov 17, 2018 | 12:14 PM
bill bosco's Avatar
looks like alot of mixed reviews on the O2 spacer
Old Nov 17, 2018 | 02:41 PM
It just isn't worth it. Leave the OEM downpipe alone, if you want to change the sound just buy an axleback.
Old Nov 18, 2018 | 07:18 PM
elkaku's Avatar
IMO.... the rv6 does make a catted version which has a o2 sensor spacer and it wont bring up a code since that code is triggered by messing around with the egr system.... not the o2 sensor....ive had it mounted for about 4-5 months now with the stock b pipe and Tanabe Medallion axle back and have had absolutely NO problems or codes...
Desmond Lamar MacRae
13
Jan 28, 2016 09:46 PM
WhEreZmYFiT
16
Feb 6, 2008 10:01 AM
kancerr
Oct 10, 2007 07:47 PM
lee_hacken
May 1, 2006 06:30 AM
peteski
Mar 5, 2006 12:41 AM
