Sea Foam
Old Feb 1, 2012 | 11:19 PM
sh00k's Avatar
Sea Foam
I searched up the threads about this and mostly everbody uses it through the lines & not through the gas tank. I used this on my car twice & always just poured it all in my gas tank. I could feel a little difference, colder ac, runs better at starts, better mpg. But I feel like i'm doing it wrong. So if you guys could feel me in on it, i would highly appreciate it.
Old Feb 2, 2012 | 09:55 AM
apexanimal's Avatar
imho:
mopar combustion chamber cleaner > sea foam...
anyday...
Old Feb 2, 2012 | 01:02 PM
Vash's Avatar
when you put in the gas tank like that it only helps with clearing moisture from the gas tank.
if your looking to clean out the cylinder chambers, you got no choice but to put it in the break booster line... and thers going to be more smoke then you can imagine coming out of the exhaust pipes... like imagine a burnout x10.
Old Feb 2, 2012 | 10:45 PM
kcle730's Avatar
Can someone provide a pix of where the brake booster is? i wanna do this
Also the best thing to do is 1/3 goes to the gas, 1/3 goes to oil, and 1/3 goes to vac
Cleans out EVERYTHING, done it to my STi and my MCS
Old Feb 2, 2012 | 10:50 PM
SilverBullet's Avatar
Use a vacuum line that goes into the intake manifold and be careful not to hydro-lock the motor. Make sure the motor is hot. Sea Foam Usage Video
Old Feb 3, 2012 | 10:02 PM
kcle730's Avatar
Got it! no worries =]
cavernap
Aug 13, 2018 02:41 AM
fitchet
Dec 23, 2017 05:48 PM
BenQuick
Apr 3, 2017 11:01 AM
tanukifit
Hawaii Community
16
Dec 31, 2009 03:59 AM
chibitul
Sep 5, 2005 12:33 AM
