FS: DIY GE8 Intake - Spectre & K&N Parts *NO CEL!!*
Old Mar 18, 2012 | 06:19 PM
MEATBABY's Avatar
!Sold!
Selling my DIY intake. Had it on for a few thousand miles, no problems. The kit consists of a 2.5" to 3" right angle 4-ply silicone coupler hose, a 3" Spectre MAF adapter tube w/ mounting plate, K&N round air filter (uber clean), Spectre small breather filter (for your crank case vent), and a "custom" () pipe clamp that I used to support the intake from the stock air box mount.
Now how I managed to eliminate getting a check engine light FOR GOOD...I just sawed the MAF tube from the stock air box until it was just the right length and width to fit inside the Spectre MAF adapter tube. Works just great, doesn't move around, and most importantly NO CEL! I know it's not the prettiest job but I assure you it does the trick. Also for the crank case vent, you could always just put a hole in the side of the silicone hose and run your vent hose straight to it using a pipe fitting. That would eliminate the breather filter and also increase your intake efficiency ever so slightly. I would also recommend fabricating some sort of heat shield for the intake to keep that heat soak down.
If you don't like the placement of the intake, I also have just a straight HPS 2.5" to 3" 4-ply silicone hose I could include as well as/in place of the right angle coupler. I've tried it both ways and there is room behind the ecu for this intake. It will work either way.
Asking $65 shipped anywhere in the lower 48. Sorry for the dirty engine bay pictures, but once I removed the intake I cleaned it all up.
Old Mar 19, 2012 | 06:47 PM
KC_fitted's Avatar
Where you located in kansas? I'm located in kansas city, let me know. interested in buying this setup. Did you see any change in fuel economy?
Old Mar 20, 2012 | 02:08 AM
MEATBABY's Avatar
Wichita. There was a slight increase in fuel economy. Would be even better w/ a heat shield and a crank case vent hose ran back into the intake.
Old Mar 20, 2012 | 01:35 PM
KC_fitted's Avatar
Nice, probably be cheaper to ship than meet up I suppose. whats your preferred method of payment?
Old Mar 20, 2012 | 03:34 PM
MEATBABY's Avatar
Paypal's the easiest.
Old Mar 20, 2012 | 04:18 PM
KC_fitted's Avatar
What's your paypal address?
Old Mar 20, 2012 | 04:37 PM
MEATBABY's Avatar
PM'd you
Old Mar 22, 2012 | 07:24 PM
KC_fitted's Avatar
Money sent
Old Mar 22, 2012 | 09:36 PM
MEATBABY's Avatar
!Sold!____
Myxalplyx
Apr 11, 2015 09:56 PM
yovtecjustkickedin
13
Apr 5, 2015 02:08 AM
slimchriz
Sep 25, 2009 08:44 PM
coldstorage5
Sep 1, 2006 01:33 AM
