Changing Stock Radio Colour
Old Mar 21, 2012 | 07:39 PM
Gaffer's Avatar
Firstly, because this pertains to cabin illumination alone as opposed to audio sound quality, I'll put this here instead of in the ICE section. Apologies if it's in the wrong place (in which case, could a mod please move it?).
OK, so pending the arrival of my tweeters, this is the last tiny mod from me for now.
I've always been a bit annoyed about 2 things in the UK Jazz:
a) The mismatch in colours - Dials are bright orange, but radio and heater controls are bright white
b) Inability to buy your own radio and colour match it because it's difficult to find RHD double-din fascias.
So seeing as I was "stuck" with the stock radio, I thought I'd see if I could colour match the radio to the dials by making them orange. Interestingly, Honda must agree with me becaue the main update from 2011 has been a change in cabin colours to make ALL of them orange (including the Multi-Function Display) with a result that the refreshed GE range looks much nicer inside with a uniform colour cabin.
As a reminder, this is what the stock UK cars look like (the blue light is not ambient lighting, it's the sub controller light - might change that to orange at some point in the future):
Anyway, here it is and, true to form, my camera skills aren't fantastic but in reality it looks a spot on match of deep orange with the dials . The MFD is white so I don't mind the steering wheel controls and heater controls staying white too - as long as most of it is orange...
...and here's how I did it:
Remove the radio:
Unscrew the Heater outlets (5 big silver screws circled in blue) at the top and the radio itself via the 4 black screws going into the PCB (circled in green) plus 3 smaller screws holding it in (circled in yellow in above). You're left with the faceplate and LCD assembly:
Next, pull the locking pin up and carefully pull the ribbon cable connecting the LCD to the main PCB up and therefore out:
Now unscrew LCD via it's 2 remaining small screws and carefully pry the metal housing off. NOTE: it is VERY easy to break either the LCD connections or glass or screen so do this slowly. I did it by putting a small flathead screwdriver into the sides of the housing and giving a gentle twist to pry it open thus allowing me to pull the LCD assembly free of the metal shroud - like this:
Next, get some needle nose pliers and straighten the four metal tabs (one is circled) to release the LCD's PCB (arrowed shows where the tabs should end up).
Now carefully lift the PCB away from the LCD screen and underneath you'll see a row of 3 SMD's on one side.
I simply bought some orange Glass Paint (can get Marabu GlasArt Num. 442 = OrangeYellow from Hobbycraft for about £2.30) as it is designed to withstand higher heat from lightbulbs so shouldn't have a problem on low heat SMD's. I then simply "painted" onto the SMD's like so in order to change them from standard white to "colour matched" orange:
Now leave that to dry and turn your attention to the main PCB where the controls are - unscrew the remaining screws to pop the board out:
Also, remove the two very small central screws and squeeze the tabs to remove the central Vol/Push/Select button - there's an SMD there too. Now the radio SMD's are actually blue so they come with yellowish rubber caps on them to make the light dimmer and more white. I simply put a dab of the orange glass paint on each one (10 in total). Again, leave to dry:
Once everything is dry (if using a hairdryer to speed things up, make sure it's not too hot to avoid damagimg the PCB components), put it all back together again.
Total time about 1 hour ish only. The main problem is remembering to ensure no dust is sitting between the LCD screen and fascia window because it will be VERY noticeable in sunlight (dust/hair/etc) if it is.
Also, the light is v v slightly dimmer in output but not by much and certainly acceptable in my eyes.
The more "professional" way to do this woud be to desolder all the SMDs and replace with same current/voltage alternatives in orange but I'm not that good with a soldering iron...
Old Mar 21, 2012 | 07:47 PM
Speedlimitz's Avatar
Nice DIY, looks like you did a great job!!
Old Mar 22, 2012 | 07:30 AM
Gaffer's Avatar
Thanks - might do the sub control light next (but that would involve a resolder with a new SMD because it might be difficult to change bright blue to bright orange with just glass paint).
Old Apr 2, 2012 | 05:03 PM
broganm's Avatar
hey gaffer love the job you did. That's a pretty unique DIY. My radio has the white color as well. I was going to install some blue lcd lights in my car. I wonder how it would look if i changed the radio to blue as well.
Old Apr 2, 2012 | 05:12 PM
Jamy's Avatar
Holy eff dude. I wish you had done this 5 months ago when I had my USDM fit with JDM gauges. You think the Orange and white is bad? Try orange and blue
Old Apr 2, 2012 | 08:34 PM
broganm's Avatar
my dials are blue, not orange. So in changing my radio to blue, everything would match.
Old Apr 2, 2012 | 08:48 PM
Jamy's Avatar
what?
Old Apr 3, 2012 | 02:38 PM
Gaffer's Avatar
@BroganM and Jamy: If you want blue, remember that the SMD LEDs for the buttons (on the main PCB) are actually blue! They each have a small yellowish cap on them that "colours" the light (actually, the yellow rubber colour absorbs just the right amount of blue to leave all wavelengths equal --- aka white light).
To turn your buttons blue, all you'll need to do is remove the rubber caps from each LED.
The LCD display, on the other hand, has the only "true" white light by using a row of three white SMDs (no caps). Also, these SMD's "fire" their light sideways (to the right in the piccie above), so you could get Blue Glass Paint, paint that side and they'll give out a blue light.
To test whether the brightness is OK, simply put 3.3v across the SMDs (a couple of AA batts should do) and they'll light up accordingly. I initially found the display too dark so simply re-did it with a thinner layer of glass paint in order to get brighter output.
Old Apr 3, 2012 | 03:13 PM
dragonxwas's Avatar
I did the same to my head unit, just that I did it the harder way, removed the amber led's and added white instead, to match with the ambient light..
now I am afraid to open up my speedo cause its under warranty..
nice writeup..reppy to ya..
yellow wolf
Oct 24, 2015 05:51 PM
damoaten
Feb 28, 2013 11:09 AM
awptickes
Jul 22, 2010 04:32 PM
Chazzlee
Mar 14, 2010 06:54 AM
AXEL
Sep 16, 2008 01:51 PM
