FS: Borg warner s300sx twin scroll turbo
Description: Up for sale is a brand new borg warner s300sx 8375. Had this and ended up selling it thinking i'm going to get an EFR, but ended up getting it again since I thought it such a great turbo. Spools as fast as a GT35r with higher power potential, more durability (journal bearing), and cheaper. T4 divided housing with .91 AR. Capable of 500-600+whp. This already has the modified discharge for a 3" v-band ($150 option from full race). Goes for $950 if you opt for this option, otherwise you get a ~4 inch discharge.
BorgWarner S300SX 8375 Turbo S360 - Full-Race.com
Taken from full race's website:
The S300SX 8375 is quite possibly the best value in today's high performance street-turbo marketplace. This is one of the smaller S300SX's in the lineup and has a high flow 68 lb/min 7 blade extended-tip compressor wheel and a 10 blade 75.9mm inconel turbine wheel with 4340 shaft. Recommended for use in quick spooling 500-600+whp applications, this is an excellent turbo for a very fast 4cyl street car. It uses a 7-bladed Extended-Tip compressor wheel w/ 60mm inducer & 83mm exducer. 4" inlet compressor housing with 3" outlet. Comes with a .91 A/R Twinscroll T4 hsg standard but upgrading to a 1.00 a/r T4 Twinscroll housing is recommended for boost levels above 25psi! .88 A/R T4 Singlescroll also available for undivided applications. This compressor moves more air than a 61mm GT3582R but with only a 60mm inducer compressor wheel to keep inertia low. Capable of efficiently pumping up to 45+ psi boost, this turbo generates big torque numbers. Journal Bearing and Oil Cooled only (watercooling and BB CHRA not applicable). Similar to a Twinscroll GT35R with higher boost capabilities at a lower price. FULL RACE RECOMMENDS MODIFYING THE TURBINE HOUSING TO 3" VBAND. (this allows for fitment identical to 40R, letting you swap between any t4 turbocharger with 3" vband outlet and guarantees perfect fitment to Full-Race turbo kits)
$875 shipped/paypalled to lower 48 states
Thanks for looking!
Thanks for looking!
HB1320
23
Apr 29, 2011 06:01 AM
porkchop
13
Feb 25, 2009 09:31 PM
kevin6767
Jul 14, 2008 10:35 PM
Masterdebater
Jan 18, 2008 02:53 AM
