about to order wheels
Old Apr 7, 2012 | 10:36 AM
liverpoolfcfan's Avatar
getting ready to order some wheels and just want to make sure I will not have any rub issues. the wheels are 16x7 +45mm offset and I will be running the stock 185's for now. I am lowered on swift springs. Input is greatly appreciated!!!
Old Apr 7, 2012 | 11:13 AM
FIT-tles Worth's Avatar
45 mm Offset is where you want to be with no issues... and with a 185 tires you for sure will be ok. some people on here are 205 50 16 on a 16 x 7 45mm and no issues on SWIFT springs.
Old Apr 7, 2012 | 01:07 PM
thank you, that is what i wanted to hear
Old Apr 7, 2012 | 01:21 PM
Would you guys recommend getting hubcentric rings? the bore is 67.1 vs the 56.1 stock honda bore. Is the wheel shaking/vibration bad without the hub rings? Also, do the stock lugs work or do I need aftermarket ones and what size? is it 12x1.5?
Old Apr 7, 2012 | 02:02 PM
MNfit's Avatar
you need hubcentric rings and yes you need lug nuts that are for aftermarket wheels
Old Apr 7, 2012 | 03:01 PM
what lugs would you recommend? and is the size 12x1.5? or 1.25? Also, where can you purchase hub rings from?
Old Apr 7, 2012 | 05:52 PM
Gorilla Automotive 71733 Acorn Chrome Lug Nut and Lock System (12mm x 1.50 Thread Size)
will these work guys?
Old Apr 8, 2012 | 08:26 AM
Anyone know if these will work?
also, what do you guys think of these hub rings? any good? I am not sure who is a reliable source for hub rings
http://www.ebay.com/itm/POLYCARBONAT...sories&vxp=mtr
seems pretty cheap to me for 4 rings, i don't know
pandayun
Apr 5, 2012 05:57 PM
Stormtrooper
Oct 24, 2008 07:00 PM
IstayFitted
Jul 22, 2008 09:18 PM
Burbio
May 20, 2008 07:47 PM
andyk
Jan 4, 2008 10:13 PM
