Retrofit?
Old Apr 17, 2012 | 12:54 AM
chinkieboy's Avatar
Old Apr 18, 2012 | 10:41 PM
jnesselroad's Avatar
None of the above. I used morimoto mini h1's from trs. It was my first retro, so I wanted it as simple as possible with as little compromise as I had to. LOVE the results. Although I think a match and magnifying glass would've been better than stock.
Old Apr 18, 2012 | 11:03 PM
chinkieboy's Avatar
Old Apr 18, 2012 | 11:05 PM
^yep, that's it!
Old Apr 18, 2012 | 11:50 PM
chinkieboy's Avatar
Do I need to take the headlight apart at all?
Old Apr 19, 2012 | 06:32 AM
krunk13's Avatar
Yep. Shove that sucker in the oven
Old Apr 19, 2012 | 09:23 AM
https://www.fitfreak.net/forums/fit-...ml#post1049179
If you want to find out what is entailed, you might want to spend a little time researching. Also go read threads at hidplanet.com.
Old Apr 19, 2012 | 09:48 AM
chinkieboy's Avatar
How's the wiring go if I purchase from Trs?? What's the difference between fx-r and morimoto mini h1?
Old Apr 20, 2012 | 01:17 AM
chinkieboy's Avatar
I'm really thinking about doing it... But where should I start?
Old Nov 12, 2014 | 09:19 PM
W204White2010's Avatar
Hi guys, newbie fit owner here.
Sorry to bring up a thread from such long time ago. I tried searching but to no avail.
Does anyone know how to remove the low beam reflectors from the headlight housings? I have my 2007 Fit Sport headlight lenses off right now, but there are reverse clips holding the reflectors in place.
I undid the height adjustment screw, and the reverse clip that's reachable. The other reverse clip is under the reflector bowl on the other side of the reflector that is not accessible.
Does anyone know how to remove the reflector bowls without breaking anything?
Old Nov 13, 2014 | 04:13 AM
DWils's Avatar
Did the link in post #7 help?
nicoli
Mar 25, 2015 12:27 AM
danger69
Feb 9, 2014 02:46 PM
GoFits
Dec 17, 2012 10:06 AM
Crawly
Jul 2, 2008 07:38 PM
spearsoft
May 6, 2008 01:01 PM
