chrome door lock knobs :)
Old May 8, 2012 | 06:28 PM
joey_fits's Avatar
I've been searching for over a year for legend chrome door pins. The other day I found these at my friendly local parts store. Dorman part #75403 anti theft style. They sit slightly above flush when locked. I think they help tie in the jdm handles and for under $4 for all four doors ( with employee discount ) worth it to do. Simple swap turn stock counter clockwise replace with new. New locks come with a rubber sleeve to place over plastic pieces so you can use a pair of pliers to loosen without damaging plastic or chrome finish. Thought id share
They don't sit perfectly straight because the oem ones have a raised portion at the bottom to guide them. I'm working on a solution now. Something like a ring around the bottom of the knob
Old May 8, 2012 | 07:17 PM
doctordoom's Avatar
Supervillain
Good idea! I commend you on this project.
However, there are some negatives to address. The fitment looks pretty bad at the moment - it's off-center and short. I know you're working on the centering, but can you manually unlock the doors if the power door lock actuator fails? From the photos, it looks like it sits too deep to manually unlock.
If you work those issues out, these may look nice. But if you can't, then they're just cheap, poor-fitting replacement door lock knobs.
Good luck!
Old May 8, 2012 | 09:20 PM
joey_fits's Avatar
Fixed! They are now centered and I have a plan b incase any power failures
Size:  41.3 KBunlocked
How I achieved this
Using the rubber cap supplied from dorman
And well plan b: if need be I put a vacuum cap in with my tire gauge an owners manuals in the glove box. It fits snugly over the lock push it on and pull up the lock. I tested the theory it works well even gave a 'pop' on release. Thank you doctordoom for pointing out that one.
Old May 8, 2012 | 09:41 PM
doctordoom's Avatar
Supervillain
Nice! It looks so fancy.
Old May 10, 2012 | 09:57 AM
EightyFour's Avatar
Not bad. BKK used Type R door pins.
Do the pins just twist off or do you just pull them out?
Old May 10, 2012 | 02:35 PM
joey_fits's Avatar
Just twist counter clockwise. They're on tight so maybe use pliers, be sure to cover plastic with cloth or rubber to prevent messing it up. Those locks are basically what I've been looking for what seems like forever. if anybody has a part # for chrome honda pins id be super stoked. I've harassed my local acura dealer numerous times
Old Jul 30, 2012 | 04:02 PM
sean5995's Avatar
well thats nice
JKID
Feb 8, 2013 10:58 AM
clemsonteg
Jan 22, 2012 10:25 PM
mike2100
Sep 12, 2009 07:24 PM
Fit4Trav
Apr 13, 2009 02:52 PM
jsnatchdiggity
Jul 29, 2008 02:32 PM
