a light close to stock offset not lowered wheel for 205/50/16?
Old May 9, 2012 | 11:54 AM
isis07734's Avatar
I dont plan on lowering the car, and would like to stay close to stock offset- but will entertain reasons not to. I like the Koseis, but think 16x7 would be better suited for the 205.
Thoughts?
Thanks!
light weight*
Old May 13, 2012 | 11:27 PM
kollunz's Avatar
Enkei RPF1s
Old May 14, 2012 | 03:32 AM
Goobers's Avatar
Kosei have 16x7 wheels... I count at least eight designs that list 16x7 from http://www.koseijp.co.jp/engfl/Wheel...t%20Guide.html (they're basing fitment on the Fit, for the BASE trim, so the tire size is slightly off).
And two of those designs even have +53 offset. (Concepto Alpha and Beta). Too bad that site doesn't list weights (or at least not obviously, since I don't see it on quick glance).
Kosei K4R Light Grey Painted looks okay, while it is 16x6.5, there are plenty of 205/50 tires that fit 6.5" rims. In fact, Continental DWS's specs are measured on 6.5 wheels.
Old May 14, 2012 | 01:33 PM
isis07734's Avatar
So it looks like I have my choice of 43, 44, or 45 offset. 53 would be extreme, huh?
Any knowledge on which offset would be best for suspension?
Old May 14, 2012 | 08:11 PM
Goobers's Avatar
why would 53 be extreme? Stock offset is 53.
Old May 15, 2012 | 09:22 AM
isis07734's Avatar
Oh! I guess it wouldn't
But would that make the 43-45's too far off? Too much strain on suspension? Or sticking out too far?
My car is black by the way- liking the look of bronze, gold, and possibly that grey you mentioned.
Old May 15, 2012 | 12:20 PM
punx45's Avatar
tire rack offers wheels for the fit in the +40s, and they are very careful with their fitments. we are talking a difference of about 10mm between +53 and +42. i think if you read around here offsets in that range are typically safe, especially if you dont plan on lowering.
Old May 15, 2012 | 12:56 PM
isis07734's Avatar
Cool. Thanks!
Old May 15, 2012 | 01:27 PM
hayden's Avatar
+45 on 16x7 with 205s is the typical setup that doesn't rub. Closer to stock offset, the better. I run 205s on stock wheels with no prob rubbing on the inside.
Old May 15, 2012 | 04:16 PM
isis07734's Avatar
ok got it, so 53 would be fine with a stock sized tire and as one gets wider you can drop in offset.
Thanks, hayden- I would too if I could, but I have the base model-
RevToTheRedline
Jan 24, 2012 01:03 PM
Cornerstrike
Oct 2, 2011 06:05 AM
kevinkidstar138
Jun 20, 2010 08:24 PM
thebluepotato
29
May 3, 2010 11:14 AM
korky
Apr 22, 2008 05:24 PM
