Questions # 2 : Both Brake lights died - bulbs ok , third brake light ok
Old May 11, 2012 | 05:45 PM
Leaky Fit's Avatar
Hi all,
The brake light on my Mom's 2007 fit (no longer leaky, fixed by dealer) died last week and when she steps on the brake now only the 3rd brake light would come on. Any suggestions?
Everything is OEM , the rest of the lights in the housing all work. Only the triangle red lights that normally would come on when you step on the brake pedal is now dead.
I checked both bulbs and they seemed fine. Tested with new bulbs, still not working.
Guessing it's a fuse?
Thanks!
Old May 11, 2012 | 06:04 PM
punx45's Avatar
I'm not familiar yet with the specific ins and outs of the GD or GE wiring but fuses are usually a good place to start!
It used to be leaky? I would check the bulb contacts too, they could be corroded. try cleaning them with alcohol, or if its really bad some sort of abrasive cleaner or fine grit sandpaper. (the idea is to polish the contact, dont grind it down!)
then bust out the multimeter and start testing connections?
Old May 14, 2012 | 12:11 PM
Leaky Fit's Avatar
Didn't get time to look at the car over the weekend, but will get to it tonight.
Oh second thought, if the third brake light is working, that it should mean the brake light fuse is OK, but the problem is somewhere down the line?
Old May 14, 2012 | 07:42 PM
Goobers's Avatar
There could be different fuses for them.
Old May 14, 2012 | 08:23 PM
Perrenoud Fit's Avatar
Could be the switch? #5 in pic
Old May 14, 2012 | 09:49 PM
Goobers's Avatar
not sure how that could be, since he states the third brake light works. I would've thought that a bad switch would prevent even the third light from working.
Old May 14, 2012 | 10:55 PM
punx45's Avatar
yeah i'd say the switch is the only thing we can really rule out. unless anyone has the circuit diagram handy to confirm/deny multiple fuses, OP is going to have to check the car out to know anything for sure
Old May 16, 2012 | 02:37 AM
Leaky Fit's Avatar
Checked the socket with voltmeter - there is power.
So...
- fuse is ok
- bulbs are ok
- brake light switch is ok (3rd brake light comes on on problem)
The left and right bulbs will even light up (at low intensity) when I turn on the night time driving lights.
But bulbs won't light up when brake pedal is depressed. (but 3rd brake light works)
I checked the fuse diagram and didn't see anything else resembling a "brake light fuse"...
hmmmm
Old Jun 14, 2012 | 10:37 PM
evil_s10's Avatar
Normally on most cars the third brake light receives power straight from the stop lamp switch. If the brake lights both show power at the circuit then you might need to see if both share a common ground. Could be corroded from the leaks?
Old Jun 15, 2012 | 01:24 AM
Leaky Fit's Avatar
Thanks everyone.
I fudged it up. it was the bulbs. Both burned out on the same day. $4.50 later and it's good as new.
Old Jun 15, 2012 | 06:38 AM
Black3sr's Avatar
Originally Posted by Leaky Fit
Thanks everyone.
So why in first post you said new bulbs did not work? What happened then?
Old Jun 15, 2012 | 11:12 AM
Leaky Fit's Avatar
cos I was a genius and I thought the top bulbs in the triangle housing were the brake lights.
Old Jun 15, 2012 | 12:03 PM
Black3sr's Avatar
It is a bitch being a genius eh? At least you came back here and admitted it. Few would have.
Old Jun 16, 2012 | 11:35 AM
evil_s10's Avatar
Glad you got it fixed. I have done the same thing, rule of thumb is to never rule the bulbs out.
Old Jan 22, 2013 | 09:38 AM
preci0uzxstar's Avatar
i had a similar problem thanks guys
Old Apr 26, 2022 | 06:03 PM
jdserrano's Avatar
Third brake light working, other 2 dead
Third brake light working, other 2 dead. Tested left and right bulbs (4) all working when plugged in third (upper) brake light on hatch. Should I go buy a new switch?
AdotHam
Aug 16, 2017 11:29 PM
MTLian
Sep 6, 2015 01:58 AM
fitfit10
Jun 8, 2015 04:21 PM
chinkyy
Mar 4, 2013 10:37 AM
crw
Aug 31, 2005 06:37 PM
