"Shock" and confusion
Old May 16, 2012 | 05:05 PM
honda2112's Avatar
So I'm starting to get some loose sounds from my front passenger side so I'm guessing the shocks are going. I've searched extensively on here on what to do but can't seem to find my case.
I've got an '07 Sport with Progress springs, the stock absorbers have lasted me 80k so I'm looking for something, well, different. I know Koni doesn't make them for the GD3 (I think) so how should I proceed?
I'm asking you, the best and the brightest of the Fit world. Thanks in advance for any advice.
Old May 28, 2012 | 02:20 AM
GoFits's Avatar
Well, if you want shocks/struts with adjustable dampening your only choices are Tokico HTS and T1R S-Type.
Otherwise there are KYB GR-2's and Tokico HP's which are apparently OEM replacements.
BUT!!!! I will add. I was starting to hear a loose sounds coming from my front suspension components and I thought it was the struts going..turns out it was the End-Link Bushings on the front sway bar (I'm all OEM under there) With my extended warranty it was replaced free of charge. ($250! otherwise) May want to check that too...
hello_you1
Jul 5, 2015 01:19 PM
Nigh-T Pedri
Apr 26, 2014 08:59 AM
ernesto1
Sep 23, 2010 06:56 PM
runbikerun
Aug 18, 2009 09:17 PM
integradriv3r
Oct 20, 2007 07:40 PM
