new rims for my fit
Old Jul 24, 2006 | 08:16 PM
metalliguy's Avatar
new rims for my fit
i have this 1.4 idsi honda jazz
it's originally fited with 14 inch wheels
now i wanna change them and put 15 inches
the tires will be: 195/45 r 15
i just want to know, what will be the changes i'll get if i do it
and if there are any changes i should do to the car
thaks pals
Old Jul 25, 2006 | 01:25 PM
Bill L's Avatar
The North American Fits come with either 14 x 6 offset 45 wheels, with 175/65 tires, or 15 x 6 offset 55 wheels, with 195/55 tires, so maybe yours will fit just fine.
To check use this: http://www.rims-n-tires.com/rt_specs.jsp
Plug in your current data & the new data, and read out the comparison-- good luck!
Old Jul 25, 2006 | 01:36 PM
jits14's Avatar
thaks pals
you might get a small spedometer redout change because the diameter of the 175/65 to 195/45 is reduced, the 195/45 tires will be a little smaller because of the lower profile tires. get 195/55s like the usdm fit tire size and it should work the same.
Old Jul 31, 2006 | 01:17 PM
jim@tirerack's Avatar
Former Vendor
The 195/45R15 is too short and would throw off the speedometer, odometer and gear ratio. It is also going to be low on load capacity and will have more gap in the wheel well. Try at least a 195/50R15 or even better a 205/50R15.
dovey
Apr 30, 2012 07:46 PM
EMC2
Apr 18, 2012 11:05 AM
panda1314
Jan 4, 2009 09:31 PM
caloyski5
Feb 21, 2008 03:57 PM
db_et_ac
Feb 1, 2008 05:37 PM
