Serpentine belt
Old Sep 24, 2012 | 11:44 AM
running's Avatar
Serpentine belt
I saw a link about changing this but the pics are gone, now, do you really have to disconnect the alternator?
Any tips would be helpful, the Fit has 80K on it, 1st gen. I know it says 100K before changing but I would like to do this before winter.
Thanks.
Ed
Old Oct 26, 2012 | 08:50 AM
Type 100's Avatar
No need to disconnect the alternator if you want to swap the drive belt out for a fresh one. I've done it myself, and it's a tight squeeze for larger hands but workable. The main thing you have to do is loosen the alternator's lock bolt and adjustment bolt. The adjustment bolt, I loosened almost to the point of removal.
What you MIGHT have to remove to ease belt swapping is the idler pulley. If you're dexterous enough you might get away with just loosening the alternator bracket, but I had to resort to wrenching out the idler pulley.
You'll need a 10mm and 12mm socket, and a closed-end wrench if you decide to take the idler pulley off.
Hope this helps!
Old Oct 26, 2012 | 11:23 AM
running's Avatar
Thanks for the info, it does sound like a belt now, it's kind of like a hissing sound that comes and goes.
Old Oct 26, 2012 | 12:20 PM
Wafulz's Avatar
make a new diy when ur done
grommet
Apr 27, 2026 09:57 PM
hstoynov
Jan 19, 2020 11:55 PM
greenmonster2420
Nov 11, 2016 02:54 PM
jilm
Apr 13, 2016 06:22 PM
lightyear22
Oct 1, 2014 07:47 AM
