Ramey Built - Custom GD3 Turbo Kit Build Thread
Old Nov 12, 2012 | 01:03 PM
RBMvrk's Avatar
Talking Ramey Built - Custom GD3 Turbo Kit Build Thread
We at Ramey Built are doing a Custom Turbo Kit on a 2008 Honda fit.
Spec's are as follows
Precision Turbo 58 / 58
Precision Intercooler
Precision Injectors
Tial Waste gate & Blow off Valve
RameyBuilt Manifold
RameyBuilt Downpipe
RameyBuilt Intercooler Piping
RameyBuilt Dump tube
Hondata Flash Pro
255 Walbro fuel pump
This is a build thread so as the parts come in and as we start fabricating the parts we will keep you updated here and on the blog
www.rblyfe.com
Old Nov 12, 2012 | 01:32 PM
DiamondStarMonsters's Avatar
Very cool.
Which turbine housing are you putting on that 5858? GNX, DSM, T3, T4 or V-Band housing?
Trying to get an idea of what sort of power and overall power-band you are looking for with that much turbo on the L15As stock cam and internals..
Care to share?
The 5858 can max out a Walbro GSS342 @ 14.5vDC on E85
Old Nov 12, 2012 | 03:33 PM
RBMvrk's Avatar
We will be running a JB 5858, With a E compressor. T3 with a .63 AR. Wont be running E85 as it's not readily available in our area, and we feel pump gas will do just fine. Dont plan on maxing the pump out as we wont be going too aggressive on the stock internals. With the 5858, spool time shouldnt be too laggy, as it's not that large frame of a turbo.
Power goals are undetermined this far.
Old Nov 12, 2012 | 04:02 PM
Very cool. Can't wait to see what it churns out.
It's not a large frame by any means but these newer wheels, even the 58mm/74mm compressor can move some serious air. I've seen a couple service 450awhp on Pump 93 with a 2.0l
I logged 67.x lbs/min massflow @ 38psi boost on one of my 2.0Ls through a 59mm/80mm Borg Warner S200sx
Rod bolts for insurance and a big cam with some good springs will let you get away with a lot more on the otherwise stock rotating assembly.
Basically keep torque/cylinder pressure relatively low and wind out farther to make a big HP figure. That's been my formula for stock block Honda builds and a side benefit is it gives a nice broad power curve and those T3 footprints will make for low drive pressure out the top end.
Anyways good luck and keep us posted!
Old Nov 12, 2012 | 04:44 PM
Wafulz's Avatar
And it begins
Old Nov 12, 2012 | 04:48 PM
TPColgett's Avatar
Tagged for future updates of more awesome
Old Nov 14, 2012 | 11:24 AM
RBMvrk's Avatar
Parts came in 11/14/2012
Old Nov 14, 2012 | 11:38 AM
Lookin good! That's a tiny inter-cooler though!
Old Nov 14, 2012 | 11:55 AM
RBMvrk's Avatar
The intercooler is rated at 350 I doubt we'll see anywhere near that on the stock motor.
Old Nov 14, 2012 | 11:58 AM
FitStir's Avatar
Thumbs up
Looking forward to see more of your build. Very nice!!!
Old Nov 14, 2012 | 12:25 PM
dewthedew's Avatar
subscribed!
Old Nov 14, 2012 | 01:25 PM
gynosis's Avatar
subscribed!
+1
This should be interesting
Old Nov 14, 2012 | 03:42 PM
RBMvrk's Avatar
Fedex just dropped some more stuff off
Old Nov 14, 2012 | 05:47 PM
RBMvrk's Avatar
The Ramey Built fit Charge Piping!
Old Nov 14, 2012 | 05:49 PM
TPColgett's Avatar
Looking super clean!!!
Old Nov 14, 2012 | 09:31 PM
FITdrummer13's Avatar
Tagged for interest! Looks good Using this for motivation for my build
Old Nov 15, 2012 | 10:11 AM
FitStir's Avatar
Thumbs up
x1000
For real!!!!
Old Nov 15, 2012 | 11:11 AM
gynosis's Avatar
Where do you plan on mounting the intake for the turbo? Engine bay is tight...
Old Nov 15, 2012 | 01:43 PM
RBMvrk's Avatar
The Ramey Built turbo manifold process
Old Nov 15, 2012 | 04:26 PM
RBMvrk's Avatar
Have not got to that point yet but turbo placement was very important during manifold design process to make room for an intake, intercooler piping, downpipe and dump tube.
