Ramey Built - Custom GD3 Turbo Kit Build Thread
Old Nov 15, 2012 | 04:32 PM
DiamondStarMonsters's Avatar
Is the 5858 going to be over the transmission on a sidewinder style manifold?
Old Nov 15, 2012 | 05:33 PM
RBMvrk's Avatar
No nothing like that, we should have the manifold done tomorrow I will post some pics of it installed.
Old Nov 15, 2012 | 09:36 PM
dewthedew's Avatar
any chance of making another manifold for me?
Old Nov 15, 2012 | 09:45 PM
FITdrummer13's Avatar
What he said! Group buy
Old Nov 16, 2012 | 06:32 AM
Type 100's Avatar
Subscribed! Good luck with build
Old Nov 16, 2012 | 12:34 PM
hehn's Avatar
I can't wait till I get home to drive it
Old Nov 16, 2012 | 06:22 PM
dewthedew's Avatar
Its your car?
Old Nov 16, 2012 | 06:45 PM
dewthedew's Avatar
not sure if you stated this but what size injectors are you using?
Old Nov 17, 2012 | 08:32 AM
hehn's Avatar
Its your car?
Yeah it's mine
Old Nov 17, 2012 | 08:37 AM
hehn's Avatar
If i remember right they are using 650cc injectors
Old Nov 27, 2012 | 01:33 PM
RBMvrk's Avatar
UpDate!
So we decided to go with a smaller turbo
-Precision Turbo 4854
New pictures
Old Nov 27, 2012 | 01:58 PM
  #32
cl juice's Avatar
looking good
Old Nov 27, 2012 | 02:00 PM
  #33
TPColgett's Avatar
Looking GREAT!
Old Nov 27, 2012 | 02:38 PM
  #34
Yea, a 48mm turbo makes a lot more sense for stock internals and it still leaves plenty of room to grow should you choose to build a rotating assembly for it lol
What turbine side? Is that still T3? .63 A/R? That housing and 54mm turbine would make for great top-end and relatively low drive pressure, suffer a bit on lag in lower gears though. Power and pull will more than make up for it.
Should make great power on pump gas (~36-38lbs/min) and won't max out the 650 injectors at the Fit's base pressure. Will you be running an adjustable pressure regulator and converting to a return-style fuel system?
Old Nov 27, 2012 | 04:19 PM
  #35
dewthedew's Avatar
looking good! how much does that turbo typically retail for??
Old Dec 1, 2012 | 03:29 PM
  #36
dewthedew's Avatar
updates??!?!
Old Dec 1, 2012 | 03:38 PM
  #37
hehn's Avatar
Sorry I took the car back for a few days. I just got off of deployment and needed to go somewhere. I'll be dropping it off with them again at the end of the week. They told me they need about another week with the car.
Old Dec 1, 2012 | 06:38 PM
  #38
pokems23's Avatar
June 2007 3rd Place Fit of the Month Winner
Looking forward to the results
Old Dec 1, 2012 | 07:14 PM
  #39
Sapper's Avatar
Have they given you a cost figure or range on this build?
I might buy a 2nd fit just to do something like this!
Old Dec 1, 2012 | 08:58 PM
  #40
dewthedew's Avatar
Any change these guys would build extra turbo manifolds?
