Ramey Built - Custom GD3 Turbo Kit Build Thread
Old Jan 26, 2013 | 09:47 PM
  #61
dewthedew's Avatar
I want this kit!!
Old Feb 6, 2013 | 10:51 AM
  #62
hehn's Avatar
It is pretty fun, but now I have to put in a new clutch
Old Feb 6, 2013 | 03:50 PM
  #63
TPColgett's Avatar
I bet a stout clutch and a LSD will make that a whole new experience
Old Apr 11, 2013 | 02:37 PM
  #64
Stevens24's Avatar
This question could go to DSM or the guys from Ramey. Would running a different intake manifold (eagle one for instance) help in a turbo application like this? And what else would you consider changing to run a setup like this at altitude(CO) or would it simply be a different tune?
Old Apr 11, 2013 | 04:11 PM
  #65
TPColgett's Avatar
The VERY short answer is yes.
To actually get DSM's attention, PM him and set up a consultation scheme/payment! I believe he has done several FI builds that had to contend with altitude...
Old Jul 27, 2013 | 08:12 PM
  #66
hehn's Avatar
got some new numbers. just had the guys at ramey built do the flywheeel, clutch and lsd.
installed a boost controller and went to 9psi. im still getting used to the clutch and flywheel though.
Old Jul 28, 2013 | 01:48 AM
  #67
loudbang's Avatar
Whew what's up with the bad spike in air fuel above 6000 those numbers are getting in serious trouble range.
Any codes after you put in the flywheel?
Old Jul 28, 2013 | 02:52 PM
  #68
hehn's Avatar
Not sure why it spikes like that on the chart. He probably let off the throttle. Took the car for a drive and the only time it leans out like that is when I let off.
No codes from the flywheel, the only issue I have right now is the stock o2 sensors are faulty. So we disabled those and ive just been watching my afr gauge.
Old Jul 29, 2013 | 03:25 AM
  #69
loudbang's Avatar
Yea could be I was thinking the same thing.
Old Jul 29, 2013 | 02:58 PM
  #70
Stevens24's Avatar
Di they do any internals upgrades(springs,retainers etc)? Just wondering what the long term reliability of this application would be?
Old Jul 29, 2013 | 03:25 PM
  #71
hehn's Avatar
no internal work done. i am only at 9 psi and i do not race this car, just the occasional spirited driving. the engine should be good for a while.
Old Jul 29, 2013 | 03:32 PM
  #72
Stevens24's Avatar
Glad to here.
Old May 9, 2014 | 12:05 PM
  #73
devmail's Avatar
Great numbers, I can't seem to get any of the previous pictures to show however. In for updates!
Old May 9, 2014 | 07:31 PM
  #74
hehn's Avatar
Nothing has changed with the car other than suspension. Eventually I'll invest more into the block and a little on the head to see if I can push 300 then keep it there for a while. I have a first gen crx that I spend my money on now.
Yeah I noticed that the pictures quit working a while ago. I don't have the pics from the build and the guy that ran the rblyfe.com website doesn't work there anymore. Next time I'm at the shop I'll ask about the pictures.
GE8FTW
134
Apr 29, 2020 01:53 AM
Gandankenexperiment
Jan 26, 2016 03:37 PM
slimchriz
72
Sep 2, 2015 09:26 PM
kelsodeez
46
Nov 24, 2010 03:17 PM
southwilrise87
17
May 21, 2006 10:37 AM
