What bulbs are you guys using for your jdm tails??
Old Dec 9, 2012 | 06:11 PM
CHRISP1's Avatar
Just a questions regarding bulbs for the jdm non-led tail lights (Ones with the two white markers).
I just installed my jdm tails I got from danny-pal and one of my lights seems to have had all bulbs burnt out..now I know i haven't cut/tore a wire etc etc because I tested the ones that came with my other light and they all work. I'm also aware this has happened to a couple people on here..
So my question is what replacement bulbs are you using for your jdm tail lights?? The ones that come with your originals cant be used on the jdm ones..so what brand, part numbers are you using? Can you get them from Honda if you show them the actual bulb? Just really need to know what type to purchase and from where.
Any help asap would be appreciated! Thanks in advance!!
Old Dec 9, 2012 | 06:46 PM
TrungLam's Avatar
Sylvania 7440, 7443, 992
Old Dec 9, 2012 | 08:20 PM
CHRISP1's Avatar
which one would be the reverse bulb?
also these will be into the jdm lights? ..just asking because originals were deff different then the ones that were sent with the lights.
Thanks!
Old Dec 10, 2012 | 05:00 AM
Black3sr's Avatar
Thanks!
I have Danny Pal Tails. I just replaced the tails with ones from Crappy Tire. Just take your burnt out bulbs there and get the same ones. There is one set of tails could be Sylvania that suggests they are 20% or something brighter. Believe them they are.
Do not bother screwing around with trying to put LEDs in them. They do not work that well. I have them in my reverse lights and are just soso.
P>S> Where are you in TO? I make it to Brampton quite often.
fitnATL
Nov 6, 2013 08:49 AM
alvie213
May 1, 2012 05:27 AM
yuudaimomo
Jun 21, 2010 04:16 PM
braziers
Feb 13, 2009 11:01 PM
towelie
Dec 2, 2007 01:49 PM
