JDM Tails
Old Feb 10, 2009 | 05:07 AM
braziers's Avatar
JDM Tails
This has probably been asked a million times but...
What do the JDM Tails consist of?
Obviously indicators, brake lights and reverse i would imagine, but do they have a rear fog?
Its a bummer in in the UK that we have to have a rear fog
Old Feb 10, 2009 | 05:09 AM
YA2_user_GD3's Avatar
JDM tails are merely just LEDs rather than bulbs. Well the reverse and signal are still bulbs but the brake lights are all LED and I have to say it looks a lot more better than the USDM tails, it has a much nicer and sleeker look to it
Old Feb 10, 2009 | 05:14 AM
braziers's Avatar
thanks, so what colour are the signal lights?
amber?
i take it they dont have a rear fog built in
Old Feb 10, 2009 | 05:36 AM
I'm not sure what you really mean by rear fog, unless your talking about the rear fog in the bumper that is in the japanese model, then no it doesn't include that. As for the signals typically amber, and of course changes color according to what bulb you use. There are a couple style of JDM tails tough.. like clear, smoked, and regular.
just search it for the pics.
Old Feb 10, 2009 | 08:24 AM
micchung's Avatar
braziers,
i have JDM tail lights on my car in the UK,
only the red part is LED. they are basically LED's which replace the red colour for the brake lights and driving lights.
Amber signal lights are the same and clear bulbs for the reverse.
however, for the rear fog lamp, i have replaced the driver's side reverse lamp and put a red bulb in instead. (its not very bright, but it passes the MOT) and wired up to the fog lamp switch up front.
mic
Old Feb 10, 2009 | 08:33 AM
braziers's Avatar
Originally Posted by micchung
braziers,
mic
thanks thats the kind of answer i need to hear!
how did you go about wiring up the fog light then?
love to see a pic of what yours look like wehn switched on.
i know who ill be coming to for help when i get my tails now
Old Feb 11, 2009 | 04:17 AM
micchung's Avatar
i haven't had time to take pics of my car lately.. (with all this snow!! in the UK)
but 'I Am Ray' has done this mod too
if you were to do this, you need to do the driver's side
Off.
On.
Old Feb 11, 2009 | 04:44 AM
jagass's Avatar
Have the same question here...
Old Feb 12, 2009 | 08:05 AM
braziers's Avatar
I didnt know ray had done it, looks good. Is there anyway you can get brighter bulbs to make it a proper fog light?
So how did you go about wiring it up? are all the connections the same from the original tails to the jdm ones?
i can imagine wiring up the fog serparetly would be quite difficult
Old Feb 12, 2009 | 09:10 AM
micchung's Avatar
i would imagine that if you have a UKDM car it should be relatively simple. it should be a case of removing the old UK housing and swapping the JDM housing, with a multi-meter find the wires for the fogs and split them from the tail lights and extending the wires to the reverse light position.
all the wiring should already be in place already as you currently have 2 rear fogs/tail lights and 2 reverse lamps on the UK car. For the JDM housing, you will only need to use 1 rear fog (you might need to paint this red or buy a new red bulb) and 1 reverse, and the bulbs should fit into the JDM housing.
the reason for me having to wire seperately is that i have a JDM car, with no fog lamps as standard, and cannot get a brighter rear fog lamp
Old Feb 12, 2009 | 12:26 PM
braziers's Avatar
ok thanks for that
sounds like it shouldnt be too difficult then. i can imagine i can use the existing fog bulb from my uk tails in the jdm housing, so should work ok once all wired up.
thanks alot for the help
Old Feb 13, 2009 | 11:01 PM
VBP08GD3's Avatar
whats a rear fog?
CHRISP1
Dec 10, 2012 05:00 AM
bowtech83
Aug 5, 2012 04:21 PM
Black3sr
May 3, 2012 11:55 AM
blackndecker
18
Jul 25, 2010 08:31 AM
Tiffany
13
Apr 11, 2008 04:24 PM
