2009 vs 2012
Old Dec 17, 2012 | 08:53 PM
corygibson's Avatar
2009 vs 2012
hey, i looked around and couldn't find an answer... does anyone know if the frames are the same for the older ge8's to the 2012? like if i bought the headlights and fenders and bumper would they be a direct fit?
Thanks- Cory
Old Dec 17, 2012 | 09:27 PM
Triskelion's Avatar
Thanks- Cory
The "frames" are the same, but there may be some body panel differences. The fit of the front fenders and grilles are different between 2011 and 2012, at least in Canada on the Chinese-assembled Canadian Fits. Buy from a reliable source and specify your year.
Old Dec 17, 2012 | 09:47 PM
Goobers's Avatar
This applies to ALL USDM GEs.
Bumper and upper grille:
-Base model: pre-2012 and 2012+ are interchangeable
-Sport: pre-2012 and 2012+ are interchangeable ONLY if you swap BOTH at the same time.
Headlights and fenders: ALL interchangeable.
Old Dec 17, 2012 | 09:49 PM
corygibson's Avatar
so when you say they are interchangeable, do you mean they are
the same either years? or are you saying you can switch them with
the other years? Sorry, just trying to get a clear answer.
-Sport: pre-2012 and 2012+ are NOT interchangeable
Old Dec 17, 2012 | 09:59 PM
Goobers's Avatar
In this case, I meant that which ever year you buy, you can fit on any year. You should already know that the bumper (and grille) for pre-2012 and 2012+ ARE DIFFERENT, even though they'll fit. edit: Bernardi lists different part #s for the fender liner (the black plastic that forms the wheel well)... so that might need to be matched to the bumper also.
But, in the case of the Base... it's actually the same, there's no change for the base bumper/grille pre/post 2012.
The headlights are different from between pre-2012 Base vs pre-2012 Sport vs all post 2012 Fits... but only in the trim color. So, practically speaking, they're the same.
Old Dec 17, 2012 | 10:01 PM
corygibson's Avatar
Roger that. Thanks for the clarification.
DannyBoy8
Feb 23, 2013 04:06 AM
DiamondStarMonsters
Aug 10, 2012 01:50 PM
pandayun
Jun 26, 2012 12:23 AM
Odie
May 14, 2012 11:33 AM
GVlog
Feb 4, 2012 01:26 PM
