parts that could be improved
Old Aug 8, 2006 | 02:25 AM
marokero's Avatar
Had my Fit up on a lift the other day to test fit some new parts, and saw a few things that got me thinking:
That is the tie-rod of the steering. It looks wimpy, even for a small car like the Fit.
Even more wimpy looking is this front sway bar link... I guess it's made of something strong, but it sure doesn't look it.
Aftermarket solutions should beef up these shortcomings in the Fit. What do you guys think?
Old Aug 8, 2006 | 07:37 AM
sillypuddy's Avatar
Someone that Posts too much
as they say, size isn't everything
the tie rod end is about the same size as most hondas
the sway bar link, it's even bigger than my 99 accord's sway bar link and that one was off a Acura TL Type S, both of which are a LOT bigger than the Fit
not sure why you would want to "beef up" these parts
-joe
Old Aug 8, 2006 | 10:02 AM
marokero's Avatar
To me they look like in really hard cornering they might snap or something
Old Aug 8, 2006 | 10:54 AM
sLiVeRwOrM's Avatar
Four Wheels Enthusiast
sometimes when your in highspeed chases you need hese kinda parts..
Old Aug 8, 2006 | 02:14 PM
cheffyjay's Avatar
I've seen problems with running really big bars--usually torn mounting points. Ugh! (Friend built a BMW race car with big sway bars etc and among other problems he had oil starvation issues in corners. Had to get an Accusump. Torn mounting points, hard on the unibody!)
The size of these parts is probably in line with the weight of the car. Most of us are used to looking at these parts on biger cars and especially cars with suspension systems from the 'parts bin' designed to work on other types of cars.
...Was it F. Porche or C. Chapman who felt that sway bars were a crutch for a badly designed suspension?
Old Aug 8, 2006 | 02:32 PM
Paulo107's Avatar
small car small parts
Old Aug 8, 2006 | 05:57 PM
aveosam's Avatar
if you want to beef up something on the sway bar, try to find universal poly urethane brushing swaybar mounts...thats what a few people have done to the aveo to reduce bodyroll which helps with speed in cornering....summitracing.com has alot of universal ones
Old Aug 8, 2006 | 06:35 PM
marokero's Avatar
But wouldn't it be possible to make a front sway bar without those links, just a continuation of the bar all the way up? Or do the links serve a purpose that I'm not seeing in the pictures? Do the ends of the links pivot during suspension travel?
Old Aug 8, 2006 | 11:47 PM
aveosam's Avatar
yea some people believe that but think why would formula one drivers have adjustable swaysbars? i dont think its because they have badly designed suspension
Old Aug 9, 2006 | 07:06 AM
sillypuddy's Avatar
it allows front and back movement as well as up and down.. it's suspension 101 :-P
-joe
Old Aug 10, 2006 | 05:28 AM
cheffyjay's Avatar
Personally, I dig swaybars and poly bushings...
I don't think the Fit rolls too much though.
Don't mean to slide off topic:
Are these parts too flimsy?
Old Aug 10, 2006 | 08:09 AM
aveosam's Avatar
they seem to be the standard size on vehicles of this size
appleica
Dec 6, 2012 03:26 AM
Carbuff2
Apr 30, 2012 08:44 PM
Marrk
Oct 21, 2009 08:07 PM
pr0jectezek1el
31
Aug 4, 2008 11:45 AM
harajuka
Jun 26, 2007 05:57 PM
