check engine
Old Jan 23, 2013 | 01:15 PM
honda junkie's Avatar
check engine
i changed the interior light bulb , and there was a shortcut , the radio,the interioir light and the central locking didht work . I found a burned fuse changed it. now there is a check engine light and the esp light ......what do you think happened , what can i do ?
tnx !!
Old Jan 23, 2013 | 01:21 PM
Dwalbert320's Avatar
Is it possible you have another fuse blown?
You could also disconnect the battery and reset the ECM to see if that will clear the fault.
Old Jan 23, 2013 | 02:51 PM
Wafulz's Avatar
put stock bulb on go to dealer
Old Jan 23, 2013 | 03:26 PM
ok the after one hour that the car was off , the check engine and the esp is gonne , now i have to fix the radio that says CODE ERROR
Old Jan 23, 2013 | 04:21 PM
jazzhands68's Avatar
your radio code is on a card that is usually in with your owners manual.
Old Jan 24, 2013 | 10:12 AM
SilverbulletCSVT's Avatar
+1
and a word of advice. Enter the code into your cell phone to always have it with you. What if you were on a road trip and the code was 1,500 miles away at your house. That would be one long and quiet drive hiome.
_
Old Jan 24, 2013 | 10:19 AM
Schoat333's Avatar
Originally Posted by SilverbulletCSVT
+1
_
That's a really good idea. Thanks.
I still don't understand why our radios need a lock code. If you steal one, you deserve the subpar audio quality that comes out of it. LOL
Old Jan 24, 2013 | 01:40 PM
Triskelion's Avatar
USDM Fits also have the radio code on a decal on the left side of the glove box. On GE's, it is the lower glove box.
Old Jan 24, 2013 | 02:41 PM
Good tips for the code but the op is showing a code error and not enter code. I think that by pulling the ECM fuse or disconnecting the negative battery lead should clear the fault and allow him to enter the radio code.
Old Jan 24, 2013 | 03:09 PM
Wanderer.'s Avatar
That is good to know, thank you.
If that's true and the radio won't let you enter the code I think this is your best bet.
Old Jan 24, 2013 | 07:13 PM
tnx for the tips ! i found the code and the radio is ok , now the last problem is the light of the dashboard that became not so bright like before , but when i turn the headlight off the dashboard brigtness is back .....
Old Jan 24, 2013 | 07:34 PM
Have you adjusted the dimmer switch? If already to max position then dimmer switch is bad. The fact that you have full brightness dash lighting when headlights off tells you this.
_
Old Jan 25, 2013 | 01:22 AM
thefit09's Avatar
Which interior light did you change? If you had a blown fuse, you should check and make sure the replacement bulb isn't touching the metal roof.
Old Jan 25, 2013 | 02:21 AM
_
where can i adjust the dimmer switch ?
Old Jan 25, 2013 | 07:45 AM
Schoat333's Avatar
Turn the trip knob, its also the dimmer switch.
Old Jan 27, 2013 | 12:40 PM
THANKS everybody , evertything is back to normal !!
PhilRai
Dec 6, 2016 07:12 PM
kitenok
Dec 10, 2015 07:28 PM
Rob22315
Aug 30, 2015 08:29 PM
markyta
Jul 24, 2013 10:48 AM
bjvalencia
Oct 11, 2011 03:16 AM
