Question on original stock air intake
Old Jan 26, 2013 | 10:57 AM
inspire007's Avatar
Hi guys i was wondering how to get some cold intake on a orignial stock air box. it's seems really cramp and Im from singapore everyday is a HOT HUMID DAY~ Any guys here got did any customized stuff? care to share with photos?
Old Jan 26, 2013 | 11:09 AM
Subie's Avatar
Scroll down to the Fit Trix section and Fit Photo section. Many have posted DIY tips and engine bay pictures there.
Old Jan 26, 2013 | 11:44 AM
Steve244's Avatar
It comes stock with some cold intake: the plastic duct on the underside of the hood (bonnet?) routes cooler air from the grill to the back of the engine bay.
The only mods I've seen are to remove the stock airbox/filter and replace it with shiny pipes and an exposed air filter element. More noise and bling, but not more cool air.
Old Jan 26, 2013 | 11:45 AM
Triskelion's Avatar
The stock air box is a cold-air intake. The air inlet is in the coolest place in the engine bay, and air from outside the engine bay is blown directly to the air box inlet by the scoop under the front edge of the hood. On a hot summer day in California or in Singapore, there is no cold air, just air that is slightly cooler than the atmosphere under the hood.
Old Jan 26, 2013 | 12:48 PM
Wanderer.'s Avatar
^What these guys said
It's already got "ram-air" stock.
If you change anything change the whole intake, but any extra power you get will not be from changes in air temp, and it won't last long as the ECU adjusts the gains out.
Honda did a good job on the stock intake.
Old Jan 26, 2013 | 03:19 PM
Triskelion's Avatar
The intake draws incoming air at 90 degrees from the air flow from the hood scoop. This is NOT "ram air", just as downshifting your trans. is not "overdrive".
Old Jan 26, 2013 | 04:02 PM
Wanderer.'s Avatar
Aw yeah, you're right, it pulls air from the fender. I never actually looked much at it and thought it came from the bottom
Well it's "cold air" anyway.
Old Jan 26, 2013 | 09:27 PM
13fit's Avatar
If you really want extra power, a drop in higher flow filter is best. Dont have to worry about piping size or anything, stock is matched perfectly to a stock motor. Just keep in mind, most filters that flow more usually filter LESS.
And by extra power, I mean 0.01 horsepower added
Old Jan 27, 2013 | 09:31 AM
inspire007's Avatar
Oh ya guy not to mention I changed my bonnet to carbon fibre. The original bonnet got a plastic funnel tat lets some air in. But my cf bonnet dun have it. Actually not a big issue just wanna see if some of u guys did some DIY and I can get some fresh ideas. Thanks guys for the reply! Appreciate!
Old Jan 28, 2013 | 08:09 AM
Schoat333's Avatar
So much misinformation on this site. It's like I'm reading political posts on Facebook or something. LMAO!
Old Jan 28, 2013 | 12:25 PM
Subie's Avatar
Get used to it. This is a public forum after all and not an engineering white paper tech reference site. Everyone has a say and it's up to us to sift through and hopefully discern the difference between real gold and fool's gold. And even then, the definition of real gold is in flux. What's fool's gold to one can be real gold to another.
Bottom line is consumers that we are, will do whatever we want regardless, depending on preferences and priorities. Common sense is priceless along with good humor... A for good entertainment value!
Old Jan 29, 2013 | 10:03 AM
inspire007's Avatar
Cheers bro~
Cordizzle4life
Jan 5, 2012 11:50 AM
Fitguy07
Aug 10, 2009 07:10 AM
theljnet
theljnet.com
Aug 25, 2008 11:33 AM
alabastersilverjazz
15
May 23, 2008 09:49 PM
F0NIX
Feb 18, 2007 07:10 PM
