Alignment after lowering
Old Mar 12, 2013 | 10:37 PM
AKSnowman's Avatar
I was curious if after going from 15in wheels to 17in and dropping it 1.6 all the way around if I will need an alignment? if so is it recommended to buy a new camber kit?
Old Mar 12, 2013 | 10:51 PM
mkane's Avatar
You have probably gained some negative camber. Toe in is critical and if not corrected you will experience premature tire wear.
Old Mar 12, 2013 | 10:56 PM
AKSnowman's Avatar
thanks mkane that helps. I just need to find a local shop that will do it after i install the springs. It seems like some places just wont do it with it lowered. Im not sure why.
Old Mar 13, 2013 | 11:06 AM
n1nj4 m0d3's Avatar
I don't think you need a camber kit for a 1.6 inch drop. Firestone offers a lifetime alignment for cheap, and they will work on lowered cars.
Old Mar 13, 2013 | 11:57 AM
Cliff's Avatar
No on the wheels, yes on the lowering springs as they will cause a change in your suspension geometry, and that affects alignment. You will need camber bolts for the front, at least I did for a 1.8" drop. Whoever does the rear will need to use shims.
Old Mar 13, 2013 | 02:50 PM
Wanderer.'s Avatar
Don't NEED camber bolts, but would recommend them.
You can't adjust the rear on GE, there's no way to shim, so you might as well just pay for a two wheel alignment.
The most critical measurement is toe, just make sure it's at 0 to avoid premature tire wear. More negative camber is beneficial, thus the camber bolts to achieve this, but not necessary.
Old Mar 14, 2013 | 10:38 PM
AKSnowman's Avatar
thanks guys. I got my Tein S Techs on last night and drove a bit today and they settled down a bit.. I am thinkin I will take your advice Wanderer and have the wheels re-balanced and the alignment looked at.
Do tire shops like Firestone carry camber bolt kits "if" i do need them? Sorry i guess I can call I am just not sure what the difference is between the original and aftermarket bolts. Is it length or something?
Old Mar 15, 2013 | 03:13 AM
doctordoom's Avatar
Supervillain
You don't need to re-balance your wheels after changing the suspension.
Aftermarket camber bolts have lobes on them. It let's you adjust the camber a bit. Hard to explain, you should Google it.
Old Mar 15, 2013 | 01:37 PM
Wanderer.'s Avatar
Yes like drdoom said no need to rebalance your wheels.
I'd just order the camber kit online and bring it in.
diedwater
Jul 20, 2009 09:30 PM
CrystalFiveMT
Feb 5, 2009 07:59 AM
kodo
May 26, 2008 04:21 PM
bdk323
Apr 17, 2008 10:57 PM
cheebz
23
Jan 7, 2008 11:33 AM
