Swift Springs/Wheel Fitment Question
Old Apr 16, 2013 | 11:31 PM
GoodFIT's Avatar
Question Swift Springs/Wheel Fitment Question
Question for Fellow Fits running Swift Springs...
I'm considering a wheel set that has a 40 offset.
If I do so, which is the better choice?
205/40/17 or 195/45/17
Are they both viable options?
Old Apr 17, 2013 | 03:13 PM
TPColgett's Avatar
There is a great thread here that directly addresses your question: https://www.fitfreak.net/forums/2nd-...ire-specs.html
Seems like This is the closest to your ask:
bl_arias | '10 MT | Swift | Tenzo DC-5 17x7 +42 | Continental ExtremeContact DWS 205/45-17 | Absolutely no rubbing at all so far
I would encorage you to use an online calculator here to compare as well : Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
Don't forget to try and get something as close to the original diameter of the 185/55R16 Dunflops which were 24.0 on the nose. A 205/45R17 will be 24.3 inch diameter and your speedo will only be off about 1% at 60mph vs a 205/40R17 which is 23.5" which would make your speedo off 2.3% (58mph when it read 60, also adding extra miles to you clock!) The 195/45R17 is even closer at 23.9" (off only 0.4%) but that extra contact patch and mechanical grip of the 205 would most likely be more fun
Old Apr 17, 2013 | 03:17 PM
205/45/17 is wat i run in the summer.
Old Apr 17, 2013 | 03:32 PM
ThEvil0nE's Avatar
195/45 is the closest to stock rolling diameter
old pics of my 17x7 with 195/45
Old Apr 17, 2013 | 04:01 PM
GoodFIT's Avatar
Is that also running swifts?
From what I read here... I didn't think I'd be able to run a 205/45/17 on a wheel with a 40 offset? (On swifts)
Old Apr 19, 2013 | 11:02 PM
GoodFIT's Avatar
Kenchan,
Do you rub at all running that size. I have a AT so I'm concerned about rubbing, if I run that size. ( AT sits .25" lower in the front)
The 205 45 17 may be pushing it on a wheel with a 40offset.
Thoughts?
Old Apr 22, 2013 | 01:37 PM
Figital's Avatar
i just ordered +38 17x7.5 rim and a set of Swifts for my GE8 sport!! i am thinking of running 225/45 rubber? Any problems? What is the ideal rubber for that rim? I live in NY (potholes everywhere) so i would like to keep close to stock rim/tire sidewall ratio, if ya know what i mean lol. i am thinking i might have to have to slightly roll the fenders, which is ok, especially if i want the beefier rubber. Does anyone anticipate any clearance issues on the INSIDE of the wheel/tire? Spacers necessary?
Old Apr 23, 2013 | 09:49 AM
Figital's Avatar
anybody know? bump.
TKE
Sep 8, 2013 06:45 PM
TAFFY GE
Jul 10, 2013 05:21 PM
FitStir
20
Jan 27, 2012 04:56 PM
RODSFIT
13
Jun 5, 2011 05:10 PM
ThEvil0nE
Jul 9, 2010 03:26 PM
