Civic Si Sound
Old Apr 24, 2013 | 10:31 PM
DatFitCray's Avatar
Civic Si Sound
Whats up guys, i have a question, I haw a 2013 Fit Sport 5spd and I wante to add a Sound to my exhaust. I dont want a really loud one or a really quiet one, id like one like the one thats Comes in Stock Civic Si's... Has that sport sound from outside and can kinda of hear it from inside... What should I do to it? Testpipe? Its also my DD and I drive 40 miles one way so itll be kinda annoying driving at 70mph with a loud exhaust. Thanks Guys
Old Apr 25, 2013 | 02:00 PM
zilla8's Avatar
I think you could go with something like the T1R B-pipe and Tanabe Medalion
Touring or Concept G exhaust.
This should give you a nice sound without being to obnoxious.If you still want more sound you could do the race converter also from T1R.
If you do a youtube search you should find a few clips of this set up for a GE8.
A&J Racing :: Specials :: T1R Exhaust B-Pipe - Honda Fit 09+ (GE8)
Old Apr 25, 2013 | 02:24 PM
DatFitCray's Avatar
Sorry, I should of mentioned I did not want to go exhaust route... Just a quick bolt on for sound. I was thinking Test Pipe but i hear alot of negativity about it being too raspy and loud for DD...
Old Apr 25, 2013 | 03:02 PM
Wanderer.'s Avatar
You ask what to do to it, and then when are told what you should do to it you say "no" and try to get someone to validate your original plan?
Why don't you just go get a test pipe, try it out, and tell us how it worked out for you? You're not leaving us many options and this has become a pointless thread since you're unwilling to change anything but the cat.
Old Apr 25, 2013 | 06:34 PM
Import Al's Avatar
It should also be mentioned that you will have an extremely hard time getting an L-Series motor to sound like a K-Series.
They are very different beasts. Our 1.5L gerbil engines can sound better, but mainly head flow and give displacement the
K engines that sportier snarl while not being overly loud/annoying.
I'd recommend researching axle-backs (keep your cat!), and intakes. My CAI does help the engine note.
Possibly a header as well (I have the DC header, GD3 though).
Old Apr 26, 2013 | 11:26 AM
Bama3Dr's Avatar
If you're looking to get a sportier sound on the cheap you could just go the DIY intake route. That would give you a much stronger engine growl for less than $100. Here's the DIY thread:
https://www.fitfreak.net/forums/2nd-...e-cai-sri.html
-Dustin
Old Apr 26, 2013 | 11:44 AM
13fit's Avatar
If you want a sportier sound, PM me. It requires about $30 and retains one mounting bolt location and the stock filter.
I think it sounds great, and since it retains almost the same mounting style, the harness does NOT need to be stretched to the sensor like some intakes, and since it retains the stock filter and sounds good, an aftermarket dropin performance filter like K&N would make it sound even better!!
Parts were from autozone
--3inch coupler (buy 2) this has an adpater ring inside one end that is removable, so its either 3-3 or 3-2.5 This says Spectre on it and has a few color choices
--12mm breather filter. this is going on because chopping the bottom intake box removes the breather partition of the box.
--90 degree metal elbow. This allows nearly same factory mounting and uses one factory bolt to do so. The elbow has the straight parts a bit long, so the is angled too much to use the second mounting bolt factory. Grinding down the ends of the elbow should allow using BOTH factory bolts for a perfect fitment. I am doing this this weekend if They would send me the replacement dremel battery I require
After this is bought, Chopping the bottom box is a hassle. I had to use a sanding cylinder for a dremel to do this. It is VERY messy! It tends to melt the plastic instead of grinding it off.
I some day will grab pictures of the finished product, but not before I get part numbers so you guys can get exact parts
I retained a few inches of the bottom box so I could use the factory clamps for the filter, as using a ton of tape proved the heating and cooling of the engine bay slowly loosened the filter up. it never fell out, but it leaked a bit and who wants unfiltered air going into their motor? Not this guy!!
Old Apr 26, 2013 | 12:13 PM
Bama3Dr's Avatar
Yes, please post pics if you can. I want to do something with my intake and this sounds appealing. I like what you mentioned about it still having a mounting point instead of the ducting and filter just hanging free from the connection to the intake manifold like most of the DIY intakes.
-Dustin
Old Apr 26, 2013 | 12:16 PM
13fit's Avatar
I need you to do me a favor and remind me via PM if you dont see pictures by tonight. Im seeing 11:16 Am on the clock right now.
I tend to get busy on fridays. No one else is gonna drink this beer up! lol
Old Apr 26, 2013 | 01:02 PM
Wanderer.'s Avatar
You should just post a DIY, i'm interested too.
Old Apr 26, 2013 | 01:24 PM
zilla8's Avatar
I would just do axleback and keep the primary cat.If you do a test pipe only,there is still a secondary cat plus resonator and the stock muffler.
I'm not sure you would get the sound you want.I know how good that SI sounds but like others said our 1.5 will never sound like Civic SI mill.
Old Apr 27, 2013 | 04:13 PM
fujisawa's Avatar
From everything I've read, it's near impossible to find an aftermarket exhaust that isn't louder than a stock sporty-car like the Civic. People tend to WANT that sound (because they're a few beans short of a chili) and be upgrading from the stock Si/WRX/M3 etc.
I'd recommend trying that intake mod first. I highly suspect that will make you very satisfied and require TONS less work than an exhaust replacement.
Old Apr 27, 2013 | 04:26 PM
13fit's Avatar
I put pictures of my intake mod in my albums for those interested
PM me if something is unclear
Old Apr 27, 2013 | 08:00 PM
Bama3Dr's Avatar
Thanks 13fit! It looks pretty straightforward. You said you were using a sanding drum to do the cutting. Couldn't you just use a cutoff wheel and cut through the plastic instead of sanding through it? I haven't looked at the stock intake pieces yet, but just curious.
-Dustin
Old Apr 27, 2013 | 08:15 PM
13fit's Avatar
Was too lazy to drive and buy a cutoff wheel
The bottom box is a pain in the butt.
Like I said earlier, if the straight parts of that elbow were a little shorter the box could be mounted in factory place with both bolts. As you can see that engine side bolt is acting like a pivot point for the whole box, and the coupler is stretched a little bit
ChrisWhite
Sep 25, 2012 06:28 PM
ian-white
26
May 7, 2011 04:28 PM
FELIXY69
May 12, 2010 10:14 AM
PwRmAd
Jul 13, 2007 11:22 PM
wobuffet
May 29, 2007 04:35 PM
