Rims and fault code
Old Apr 25, 2013 | 07:10 PM
PNG's Avatar
PNG
Rims and fault code
Hello, I'm new to the site. I assume the GD and the GE, which define the 1rst and second generations, are within the VIN. I believe I have a GD first gen model.
I live in WI, and wonder if other WI owners slide around through the winter like I seem to. Wondering if another set of rims and more aggressive snow tires would help. Rim choices?, and how is the pressure sending device dealt with?
Lastly, engine icon fault light is now on. Local shop says they've no idea, something to do with evap system. Honda dealer, over the phone said the fault code 2422 may be caused by the fuel filler cap being loose. It'd need to reset with normal driving over two days after I retighten the cap. Thoughts?
Thanks, folks. Next time I do a better job of researching the previous threads.
PNG
Old Apr 25, 2013 | 08:02 PM
bb1lovin's Avatar
Try it! Should be a quick 5 minute job of tightening the cap and unplugging the battery to reset the code..good luck!
Old Apr 26, 2013 | 01:09 AM
Jazz_Pinkz's Avatar
yup, you are right GD is the first model, and GE is the latest model..
Old Apr 26, 2013 | 01:57 AM
loudbang's Avatar
Just re-tighten your gas cap until it clicks several clicks and drive it the light on the dash will go off by itself after awhile.
Old Apr 26, 2013 | 09:08 AM
Carbuff2's Avatar
Regards sliding in snow, yes, another set of rims with dedicated snow tires would stop that.
The '07 did NOT have TPMS (tire pressure monitoring system) but the '08 - on did. The Honda system can only recognize four sensors at once. So, a trip to to the dealer (or these days, perhaps a tire store) is required to make the system accept the different sensors each changeover. Of course, you could just ignore the light in the dash.
Old Apr 29, 2013 | 03:01 PM
rodpaine's Avatar
Originally Posted by Carbuff2
Snip... The '07 did NOT have TPMS (tire pressure monitoring system) but the '08 - on did. The Honda system can only recognize four sensors at once. So, a trip to to the dealer (or these days, perhaps a tire store) is required to make the system accept the different sensors each changeover. Of course, you could just ignore the light in the dash.
Depends on what state you live in. Here in VA an illuminated 'TPMS' dash light is an automatic State Safety Inspection rejection. The light HAS TO BE OUT. Also here in VA, services that can clear the light (tire dealers, Honda, etc.) typically charge $40-$90! It's not a good situation at all.
payluder
Jun 28, 2016 01:06 PM
gizmodog
Apr 17, 2014 10:00 AM
ztyhurst
Jul 8, 2012 09:06 AM
Goodguy-Fly
Jun 15, 2009 12:32 AM
docjim2
Dec 28, 2006 05:06 AM
