Quick Coil Pack Question regarding the order for cylinders
Old Apr 30, 2013 | 09:12 PM
jthompson's Avatar
I know there are tons of other threads about this, but for whatever reason I cannot find the list for which coil pack matches for which misfire. (Yes I have spent the last 3 days looking this up, but I apparently suck at finding stuff ).
Long story short, brought the fit to a shop and they replaced coil 1 and 2, now the car is giving me grief on cylinder 3 & 4. I bought the coil packs, but not sure of the order as I only need to replace the final two. This is an '08 Fit Sport 160k miles.
Any help would be greatly appreciated!
Old Apr 30, 2013 | 10:59 PM
thebrownhippo's Avatar
I would just pull them one by one with the engine running until you find one that doesn't change the idle. that's assuming it is misfiring at idle.
Old Apr 30, 2013 | 11:06 PM
DrewE's Avatar
In this situation, can't you just replace the two old grungy ones and leave the two clean new ones in place? Or was the garage replacement some time ago?
Old Apr 30, 2013 | 11:12 PM
Old Apr 30, 2013 | 11:52 PM
Hootie's Avatar
Cylinders 3 and 4 will be the two on the right when you are facing the engine/engine bay.
Just for the record, Cylinder 1's coil pack is closest to the serpentine belt and pulleys, then cyl. 2, then 3, and finally 4 of course.
As for misfires (need clarification on codes I presume?), you basically have 5 misfire codes...
P0300 -Random Misfire
P0301 -Cylinder 1 Misfire
P0302 -Cylinder 2 Misfire
P0303 -Cylinder 3 Misfire
P0304 -Cylinder 4 Misfire
Old May 1, 2013 | 10:58 AM
jthompson's Avatar
Thanks that is exactly what I was looking for, and yes it has been about 4 months since the coil packs were replaced at the shop.
Looks like this is going to get to be even more fun, I got the two replaced and the car is running worse
Old May 1, 2013 | 02:13 PM
jthompson's Avatar
Found the new coil pack was faulty, "Import Direct" is the brand of the coil packs. I am starting to wonder if that is something I should be worried about.
Old May 1, 2013 | 02:35 PM
TPColgett's Avatar
I wouldn't have put anything but new OEM (Hitachi brand) Coils on.... Not worth it, as it seems that most other brands have quality issues...
The research was already done here in this thread to find the exact part number: https://www.fitfreak.net/forums/1st-...ml#post1178354
At $53 each still not cheap, but better to only have to go through it once...
Old May 2, 2013 | 08:36 PM
fireemt24's Avatar
Replace them.all.. Old.coil packs will put a strain on the new.ones .. Rule.of thumb with these cars when.u.replace one.coil pack.replace them.all i bought 4new.ones.on ebay for 129.00 worth every.penny considering a new.one.cost about 100.00 from auto zone..
Old May 3, 2013 | 02:45 AM
loudbang's Avatar
AH no.... coilpacks are independent and one OLD OR NEW has NO EFFECT on the others.
Old May 3, 2013 | 12:45 PM
13fit's Avatar
WOW you are confused.
Coil packs are per cylinder, they are not feeding more then one on these cars.
Even if one spark plug goes bad you dont have to replace all 4.
Something like 1 bad, all 4 replace would be like the older motors and their spark plug tube seals. cannot replace one, as thickness will vary and cause 3 others to leak
FitBoy000
Aug 4, 2024 01:24 PM
Czesc
Jul 9, 2015 11:47 PM
Mtwalenciak
Dec 23, 2014 10:04 AM
dtgrosse
Jul 17, 2014 01:04 PM
jthompson
Apr 30, 2013 09:11 PM
