So picking up a short ram want info on this brand
Old May 30, 2013 | 10:43 PM
Stayfit07's Avatar
It's a weapon r short ram was gonna run it with a heatshield I have heard that with there intakes gains tend to be a little better because of the filter type, and the way the piping is made different than normal? Would this benefit the fit more? Even just a little? Since normally the gains are next to nothing on a fit? How about mpg increase? Any info appreciated. Thanks guys
Old May 30, 2013 | 10:53 PM
13fit's Avatar
I never felt a noticeable power difference when I have my filter on or off. Just noise.
Intakes on our Fits give us RESPONSE moreso then power.
The power part of it will come when we have a plug and play tuning solution.
My MPG increase from my modified intake came from me being able to BETTER understand when the car is lagging. In some cases around town, this allowed me to find out 3rd gear was better for 25mph driving then cruising in 5th.
The slightest uphill while in 5th knocked my mpg gauge down to 14ish. Staying in 3rd it stayed at or above 20mph when going uphill.
I also have my tires pumped up to 40psi which helped a lil with MPGs
Old May 30, 2013 | 10:57 PM
Stayfit07's Avatar
So let me ask u this what mph do u shift into different gears to increase the mpg? And what mph do u shift to help the car go a little quicker? And the intake will help the car a little with getting up of the line?
Old May 30, 2013 | 11:33 PM
Stayfit07's Avatar
Cuz I know with my focus it had a light built in that told you were to shift up to the next gear for best mpg and it did make a difference when shifting I'm that spot. However as far as the best spot to shift for pick up and best driving experience it wasn't where the light said to shift
Old May 31, 2013 | 04:50 AM
loudbang's Avatar
Which model do you have. The GD will benefit from mods to the intake as the ECM does NOT cut back but the GE suffers from a "bloomberg" granny ECM that will try and reduce any mods back to stock status.
Old May 31, 2013 | 06:13 PM
Stayfit07's Avatar
I have a 07 gd
Old Jun 1, 2013 | 01:06 AM
loudbang's Avatar
You are in luck.
Old Jun 1, 2013 | 01:11 AM
Stayfit07's Avatar
He'll yea lol
Old Jun 1, 2013 | 03:28 AM
MNfit's Avatar
if you plan to do any kind of engine mods to your GD3 Fit I really recommend getting a flash pro. It will allow you to ge the most out of any moda you put on the caar
ImPuLsIvE.ca
Nov 26, 2014 02:19 AM
fit246
Nov 13, 2011 08:14 PM
Sam Misled
Sep 26, 2008 12:46 AM
whitey810
Jun 9, 2008 06:25 PM
docjim2
Jul 19, 2006 03:25 PM
