map lights
Old Jun 10, 2013 | 04:52 PM
gizmodog's Avatar
map lights
having owned a 09 sport with the map lites between the visors and now owning an 013 without them i noticed the head liner had the indentation for the map lite assembly.....i would think the same wiring harness is used for either models....questions: has anyone ordered a map lite from honda or gotten one from a wrecking yard and installed it in a base model ffit?
thanx,
gizmodog
Old Jun 10, 2013 | 06:47 PM
DrewE's Avatar
People have. There's one or two threads about it here if you search; unfortunately, most of the pictures have disappeared. It works out pretty much as you'd expect it to work, which is to say, pretty well.
The wires on the base don't extend to the map light area, so you do need to run a couple of wires from the dome light. It appears to be a bit of an annoyance, but it's not rocket surgery, so to speak.
If you get one from a junkyard, you could probably also get the mating electrical connector easily, which would make the install easier (than trying to solder the wires onto the connector on the map light unit).
Old Jun 10, 2013 | 10:26 PM
gizmodog's Avatar
thanx drewE.
i'll keep my eye peeled for a fit in the wrecking yard though so far i haven't seen nary a one!......maybe i can find a decent parts outlet on the net thats discounts factory honda parts.
gizmodog
wdb
May 28, 2014 11:45 AM
TwoFits
Feb 2, 2013 08:13 AM
y950129
Nov 26, 2011 05:14 PM
j's_fit
Jun 21, 2010 08:30 PM
aznbigman
Jul 13, 2009 05:35 AM
