17x7 wheel?
Old Jul 10, 2013 | 06:14 AM
Stay_Fitted's Avatar
Question 17x7 wheel?
Hi I was wondering if i get 17x7 rims with 205/40/17 tire will i rub??? and i do plan to lower my car on Tein S Tech and once i get some more money im going to get Megan Coilovers
Old Jul 10, 2013 | 08:55 AM
solbrothers's Avatar
what is the wheel offset? You should be okay with that size, though
Old Jul 10, 2013 | 09:13 AM
Speedlimitz's Avatar
I'm running 17x7.5 45 offset on 205/45 tires with no rubbing. Full drop on twin basis coil overs
Old Jul 10, 2013 | 11:17 AM
explain to me "full drop on twin basis coil overs"
Old Jul 10, 2013 | 11:38 AM
I meant full drop on *tein* basis coil overs. Stupid auto correct on my phone
Old Jul 10, 2013 | 11:56 AM
2poler's Avatar
I am running the same offset and tire size with a 2 inch drop in the front and a 1.8 in the rear. Without camber bolts I rubbed daily in the front (just a little tire rub) but rarely in the rear (had to be a big bump). With the camber bumps I now only rub on occasion. I just took a 700 mile trip and only rubbed about 10 times and of those a couple where my fault not the car.
Old Jul 10, 2013 | 03:34 PM
how many mm did you drop your car?
Old Jul 10, 2013 | 03:35 PM
what kind of springs or coilover are you using?
Old Jul 10, 2013 | 03:36 PM
i would be using a 45mm offset
Old Jul 10, 2013 | 04:50 PM
2poler's Avatar
Used some cheap Dropzone springs (ebay special) Should have been a 1.8 F and 1.5 R and ended up being a 2.0 F and 1.8 R (50.8mm F and 45.72mm R)
Old Oct 16, 2013 | 11:54 PM
Ernesto12's Avatar
Lowered on Tein lowering springs with 17X9 +22 215/45. I had fender.work done to prevent rubbing. My tires stretch 1 inch out, 1 inch in. I'm poking about 2 inches in the front, 1.5 in the rear.
Old Oct 17, 2013 | 12:18 AM
gonna need pictures
Old Oct 17, 2013 | 11:50 PM
Ernesto12's Avatar
fit304
Mar 31, 2015 01:13 PM
HONDA4LIFE420
May 5, 2014 03:42 PM
Nicotine
Jun 5, 2012 01:55 AM
Manga_spawn
Jul 14, 2011 09:03 PM
Skytraveler
Jan 31, 2009 04:08 PM
