Sponsored by:
Sponsored by: CARiD
Disabling DRL warning light for 2013 Honda Fit
Old Jul 31, 2013 | 05:56 PM
SHOELAC3D's Avatar
Does anyone know how to disable the DRL (Daytime Running Lights) on a 2013 Honda Fit. I recently just installed HIDs and DRL warning light comes on anyway to remove it
Old Jul 31, 2013 | 06:45 PM
13fit's Avatar
remove DRL fuse
7.5 amps
under steering wheel side of dashboard
headlight switch is still fully functional
Old Jul 31, 2013 | 10:28 PM
SHOELAC3D's Avatar
Originally Posted by 13fit
remove DRL fuse
7.5 amps
See I did that before took it out completely, then my car didn't start it was weird and I know forsure it was the right one I looked in the manual and it was the only 7.5
Old Jul 31, 2013 | 10:30 PM
13fit's Avatar
i may be wrong and might be 10 amp.
eitherway my 2013 has no DRL fuse anymore and my car starts fine. check and make sure you didnt bump another fuse loose
EDIT just forget the manual, the fuse cover has the diagram!
Old Jul 31, 2013 | 10:42 PM
SHOELAC3D's Avatar
You have a 13 fit also and you don't get that DRL warning light on your dash? Yea man I'm like pretty sure it was the 7.5 fuse but imma double check again and try again cuz if yours works then mine should work fine
Old Sep 29, 2013 | 02:00 AM
Emoesque's Avatar
Old Sep 29, 2013 | 12:57 PM
13fit's Avatar
remove DRL fuse whenever you intend to use bulbs that use a DIFFERENT wattage. HIDs are lower wattage, superbright bulbs are 9 times out of 10 higher wattage
Factory bulbs are LONG LIFE bulbs that can deal with the negative effects of using DRL circuits that are simply low voltage "Lows"
short term: Remove DRL fuse. Plain and simple
j5ive
Canada Fit Forums & Clubs
18
Sep 16, 2014 01:52 PM
alanchan
Jun 1, 2012 12:05 AM
tat~
Feb 21, 2010 11:53 PM
Marsbars
Sep 25, 2009 06:47 PM
fit2bcrazed
Nov 30, 2007 03:43 PM
