Sloshing water sound when car starts
Old Nov 24, 2013 | 08:43 PM
aZnCdn's Avatar
Hi all,
I have a question when I first start up the Fit (like first thing in the morning after the car has sat for a while) and drive away. I can hear what sounds like liquid sloshing around. I am really not sure what is causing it. I have tried moving the steering wheel around, turning the A/C on/off, and pumping the brakes. I did all these tests independently of each other and one does not have any barrier on making the noise.
The noise disappears after about 30 seconds of driving and will not happen until the next morning.
Any suggestions would be appreciated.
Old Nov 24, 2013 | 09:13 PM
fujisawa's Avatar
Hi, be aware the Fit has its gas tank below the driver's seat - quick stops or gos make it slosh about. That's likely it, not sure that it would come or go ..
Old Nov 24, 2013 | 10:01 PM
aZnCdn's Avatar
I doubt it cause it goes away in the first 30 seconds of driving...
Old Nov 24, 2013 | 10:48 PM
Katsumoto's Avatar
Could be the antifreeze/water entering or leaving the heater core.
I have something close, and I think thats what my issue is. But theres no leaks, no issues so no care.
Old Nov 24, 2013 | 10:50 PM
SilverBullet's Avatar
Sounds like the fuel pump which is under the seat.
Old Nov 25, 2013 | 09:58 AM
DiamondStarMonsters's Avatar
Top off and then burp your coolant system.
Had just done this the weekend before a vengeful tree smashed my poor GD3 to bits.
Old Dec 12, 2013 | 04:58 PM
kreyn49's Avatar
I have the same problem. Was at the dealership today and they can hear water going into the heater core. They are researching the problem and will get back to me.
Old Dec 12, 2013 | 08:29 PM
2poler's Avatar
I recently did this as well and all but eliminated the issue.
Old Dec 16, 2013 | 04:44 PM
JdmMac's Avatar
I have the same issue and have been doing research on it and it's more than likely exactly what Diamond Star Monsters said. I will be doing it later this week and if I remember will update on here if it fixed it.
Old Dec 17, 2013 | 07:10 PM
E J's Avatar
E J
There's a service bulletin for this problem. It's #08-096.
There is air trapped in the heater core.
The fix involves jacking the front of the car up so that the radiator fill cap becomes higher than the heater core, allowing the air bubble to flow out of the system. Then top off the coolant.
My local independent garage knew about the problem and fixed it while I had it in for state inspection. Takes like 30 mins.
Old Dec 29, 2013 | 08:08 PM
cstephens's Avatar
My '07 Kia Spectra had this same issue, and there as also a Kia TSB on it. Same cause (air in heater core) and same fix. Instead of jacking up the front, I just parked on an incline and did the coolant top off with engine running. Worked perfectly.
Old Jan 6, 2014 | 05:33 PM
derykisonder's Avatar
I had the same issue. I'm not 100% site if this will fix your issue but when I went to my mechanic he changed all my fluids but he also noticed that my radiator was cracked so maybe you have a cracked cap
Old Feb 19, 2014 | 09:32 PM
sadtaz's Avatar
I have the same issue.....
I found the coolant reservoir is almost empty. Then I fill it up and never heard of the sound again....
CptanPanic
Aug 30, 2015 10:01 PM
nodelock
Oct 25, 2012 05:43 AM
Ric01
Jan 5, 2011 09:19 PM
jdzz
Jan 8, 2009 04:01 PM
fit73
Feb 11, 2008 03:36 PM
