Sounds like a small compressor?
Old Dec 2, 2013 | 07:46 PM
lewjac3's Avatar
Hi all,
About two months ago I noticed a noise that my 2010 fit sport was making,at first not very often now is seems it is getting more frequent.The best I can describe it, it sounds like one of those small compressors filling the tank, the noise last for about 2 seconds when I am accelerating, it seems to me around third gear. I have not heard it while doing highway speeds. Unfortunately my warrantee is up, anyone have a clue ? I was thinking a solenoid maybe for some reason
Old Dec 3, 2013 | 07:08 PM
DrewE's Avatar
Automatic or manual transmission?
Anyhow, the sound could be a bunch of things. A couple that pop to mind are a loose heat shield rattling around or an out-of-balance tire—more likely the first one. (The tire would generally vibrate at a rather specific speed, and would often be easily felt through the steering wheel as well as the car shuddering a bit.)
It would be helpful if you could figure out where the sound is coming from. That's probably rather difficult, I realize, since you probably shouldn't accelerate down the road while someone is poking their ears under the car hood.
Old Dec 3, 2013 | 07:28 PM
lewjac3's Avatar
Drew, It is a automatic, I thought all fit sports were auto? Check the heat shield it's not loss. Tire no way, I know what that fells like. I was talking to someone today and I came up with another description of the sound, it sounds similar to a mini jackhammer that last's for one second. The person said he look more toward the transmission being the source. It sounds like it is coming from around gas pedal area.
Thank's for the help
Old Dec 3, 2013 | 09:20 PM
13fit's Avatar
Check and see if you have any leaks in your intake tubing and box
If aftermarket intake, might be a loose filter, and the rubber around filter is "burbling" as its sucking air in.
tomsandoval
Jul 23, 2016 11:55 AM
pentium77
May 21, 2015 02:20 PM
Brain Champagne
Feb 28, 2014 03:51 PM
ltd
Apr 23, 2012 06:41 PM
da_roamer
Oct 7, 2009 06:24 PM
