HELP: Installing Front Coilovers for GD3
Old Dec 6, 2013 | 07:01 AM
frenchfries's Avatar
What are you guys using to hold the strut piston in place while torquing down the upper nut into the shock tower?
I tried using a 10mm wrench and vise grips on the upper flat portion to hold the strut piston from spinning but I can't seem to really get a grip and it's causing me to damage the upper thread...
*** Forgot to mention I'm installing the Skunk2 Pro-C Coilovers on my 2008***
Old Dec 6, 2013 | 09:18 AM
hehn's Avatar
I have b52 coilovers on my fit and I took off the adjustment knob on top and put an Allen wrench in it's place
Old Dec 6, 2013 | 09:44 AM
The allen knob for the pro-c is the setting for struts dampening....Would that possibly damage the adjustability by misusing it in that fashion?
Old Dec 6, 2013 | 09:51 AM
hehn's Avatar
Can you remove the adjustment knob? If so the inner diameter should be the shape of a larger allen wrench. I don't have any experience with the pro-c, but I am on my second set of coilovers and they both have been pretty much the same
Old Dec 6, 2013 | 10:04 AM
The plastic knobs are removable but other than that, nothing else is coming off to fit a larger allen key..
Old Dec 6, 2013 | 06:32 PM
Any pro-c owners out there?
Old Dec 6, 2013 | 08:57 PM
Hootie's Avatar
You would need to get the correct sized wrench or adjustable wrench that holds to the flattened section on the threads to prevent it from rotating and use a ratcheting/boxed end wrench to tighten the nut down.
If all else fails and you have to use a last resort, lightly tag it a couple times with an electric or air impact to get it started/tightened. Note: I'm not accountable for any damages if this is under/over tightened.
GinoLicious
16
Apr 24, 2015 03:20 PM
killswitch9
Nov 3, 2014 06:32 PM
Kolbotn
Aug 18, 2013 06:05 PM
Undercover
Apr 17, 2011 04:03 AM
SukebePAUr
Jul 18, 2008 09:47 AM
