Caliper bolt problems?
Old Dec 11, 2013 | 01:16 PM
buttersandpaper's Avatar
Hi, I was wondering if anybody that done their own brakes came across a problem after installing brakes. I've cahnged my brake pads twice on my car since owning. The last time I changed my brake pads was last year. Just last Monday morning when I was driving from Miami to Atlanta, the top caliper bolt came off, causing the caliper to rub against my wheel. It kind of made it sort of undriveable? Anybody ever came acroos this problem?
Old Dec 11, 2013 | 01:52 PM
Katsumoto's Avatar
Its probably related to when you last did the brakes.
The bolt could have been not tight enough and over time it backed out.
Old Dec 11, 2013 | 02:06 PM
tonkatsu's Avatar
Ok that sounds quite dangerous really, if in doubt invest in a torque wrench and get yourself a electronic service manual to avoid a repeat
Old Dec 11, 2013 | 06:12 PM
n9cv's Avatar
It sure sounds like improper bolt installation (not tight enough). I have never seen that happen on any vehicle but it sure could if the bolts were not tightened properly.
Old Dec 11, 2013 | 06:20 PM
palos's Avatar
I'd recommend using Loctite 242 Blue on the caliper related bolts.
Old Dec 11, 2013 | 07:45 PM
TPColgett's Avatar
This actually happened to me a year ago. Was coming down the grapevine in CA and had a horrible sound as the caliper bolt came out.
Never found a reason for it. Had never touched the brakes.
Replaced it with a Honda OEM bolt eventually. Most CERTAINLY used locktite on re install.
Old Dec 12, 2013 | 11:54 AM
Mine was really tightened too. Yes, I will put some loctite on it. Thanks everybody.
So it is
Dec 22, 2018 11:34 PM
powerzamcam
Apr 11, 2017 05:27 PM
esnave09
Jul 21, 2016 11:53 PM
jimsmith101
Sep 7, 2011 09:22 AM
nam_s
Oct 22, 2007 01:47 AM
