AT Transmission cooler for the Fit
Old Aug 23, 2006 | 05:16 AM
simons2k's Avatar
I'm looking for an aftermarket transmission cooler for the Fit. Has anyone ever thought of this too? Any suggestions?
Old Aug 23, 2006 | 10:32 AM
sLiVeRwOrM's Avatar
Four Wheels Enthusiast
wrap it in copper.. iam sure you can find one to Fit no pun intended..
Old Aug 25, 2006 | 03:24 AM
koolkevin1107's Avatar
well...i did this setup w/ my old auto 92 civic hatch. Most auto trannies have built in AT tranny coolers. They are just lines that run from the tranny to the bottom of the radiator and back out the other side of the radiator and back to the tranny. The AT coolant just runs through a tube that the radiator coolant surrounds to keep it cool. I hope u get it.
Newayz, i purchased this for my hatch...
http://store.summitracing.com/partde...5&autoview=sku
It is super high quality transmission cooler from Summit racing's own brand of parts. I purchase parts from Summit RAcing all the time (for my 450hp RV project )
All you gotta do is find out which rubber line is the inlet and which is the outlet. then u take the inlet from the tranny to the inlet of the tranny cooler and take the outlet of the tranny cooler and hook that up to the inlet stock radiator tranny cooler. You do not have to touch the radiator tranny cooler outlet pipe that goes back to the tranny. I hope i didn't confuse u.
To be honest, i dont think our cars get hot enuf for you to need anything more then the stock tranny cooler. For my 92 civic hatch, i had it turbo'd and tuned @ 175hp (yes on the stock auto tranny and engine) and the cooler was a necessity b/c the tranny would get like 2x hotter lol.
Old Aug 25, 2006 | 05:20 AM
simons2k's Avatar
Thanks for the info Kevin. It all makes sense. I plan on doing a few track events with the Fit and I just want to keep the temp down on the track. Anything I can do to stack the cards in my favor.
I will look into Summit.
Old Aug 25, 2006 | 03:48 PM
well...you could upgrade the transmission coolant to a higher performance one such as ROYAL PURPLE trick-shift AT transmission coolant. I was also running this coolant in my EG and it held up nicely. Made my 92 auto tranny shift like a 2007 tranny. Cleaned it up a bit. You could also invest in a magnetic transmission fluid plug. Basically it is a tranny plug w/ a powerful magnet on the end of it to pick up small particles. I recommend this one from Mfactory (same company i purchase my HID's and magnetic drain plugs from) and there company is super high quality stuff.
http://shop.mfactoryhk.com/products....0Drain%20Plugs
Hope it helps! You betta take pix of ur fit on da track.
Old Aug 26, 2006 | 03:14 AM
simons2k's Avatar
Thanks for the link. And for sure pics with track trim will be posted.
doctor J
Jan 23, 2019 03:02 PM
Bugzs15
Nov 5, 2013 06:57 PM
john21031
Oct 19, 2009 10:45 PM
theo.chan@gmail.com
Oct 19, 2005 02:39 PM
Fijoy George
Aug 10, 2005 12:20 PM
