connector question
Old Aug 24, 2006 | 01:36 AM
Chikubi's Avatar
connector question
Just wondering if anybody might know what this connector is and where I might be able to buy a M/F set. It's the plug on the engine harness that connects to the intake temp sensor. From looking at the parts sites I've found, Honda only sells the harness and the parts guy at the dealer in town couldn't find any info at all. I need it to make an adapter, so any help/advice would be great. Thanks!
Old Aug 24, 2006 | 05:34 AM
8251reefer's Avatar
I believe you could just get the same type (gauge wire and splice in new wires probably 20-24 gauge). You will probably increase the wiring resistance but it will be minimal at best. You will have to cut away the sleeving appox 3-4 inches up. Get some wire strippers and some wire splices with environmental shielding (plastic). I work on aircraft as an electrician and flight engineer and thats how we fix our broken wires. If you can't find an adapter that is what you are going to end up doing. I am not sure how much experience you have with wiring but if you are inexpercienced you might be better off having a professional do it..JMO..Good luck!!
Old Aug 24, 2006 | 11:07 PM
Chikubi's Avatar
Thanks for the suggestion, it may come down to that if I can't get my hands on that plug. I really want to avoid cutting the harness if at all possible, hence the adapter idea, but it may be impossible to avoid.
Greasyman
Mar 15, 2025 11:15 AM
Vash
Dec 15, 2011 03:50 AM
2010Fit
Jul 23, 2010 11:09 AM
FitStir
May 15, 2009 04:28 PM
fitster
Oct 22, 2008 08:56 PM
