Why do the engineers put spark plugs in the back?
Old Feb 23, 2014 | 01:32 AM
lukeskywalker1's Avatar
When I changed them a piece of gunk dropped in and now Ive got a nice little misfire in number 4.
Old Feb 23, 2014 | 02:13 AM
Goobers's Avatar
I was going to say that I don't think it would matter much if the spark plugs were in the front when it comes to crap falling in...
But then again, with the opening in the back, it means that, even if you took off the cowl, part of the Fit's sheet metal is above the spark plug holes. That is usually enough to prevent most random debris from falling in.
Old Feb 23, 2014 | 05:42 AM
2010FitSport's Avatar
Even though its going to take work, take that plug back out and check it for damage. If you want to test where the misfire is coming from, swap the plug in cyl 4 with cyl 3 and swap the coil in cyl 4 with cyl 2. If the misfire moves to 3 it was a bad plug and if it moves to 2 its a bad coil. Better to do this simple test than to guess something damaged the inside of the motor.
MSILVEST04
Jan 25, 2022 08:56 PM
MEATBABY
20
Apr 28, 2017 12:50 PM
Buildingteapots
Dec 11, 2016 08:38 PM
noelrobles22@gmail.com
Jan 21, 2016 09:00 AM
azep
Sep 26, 2014 02:08 PM
