2010 honda fit spark plug change
Old May 21, 2014 | 12:37 PM
Chaza's Avatar
Hey everyone how do I get access to change 2010 honda fit spark plugs?how do I remove the cover?
Old May 21, 2014 | 05:45 PM
p nut's Avatar
I've never done it on a GE, but you need to move the plastic cowling in order to reach the plugs. Some have said you can reach around if you have skinny arms. It's apparently a 20-30 min job, but again, no personal experience.
This is when I miss the good ol' B-series engines. 4-minute cake walk.
Old May 22, 2014 | 05:38 AM
Black3sr's Avatar
Take the wipers off first( Pry cap off then remove nut). Then the two corner pieces. They come off by prying at the bottom next to hood and then sliding up.
The center pieces come off by prying up at the glass side then the hood side will release. Have to disconnect the washer hose once the piece is loose.
Old May 22, 2014 | 05:49 AM
Chaza's Avatar
Thanks....I will give it a go. If you guys can upload any picks much appreciated. I don't want to take it to the dealer and pay a fortune.
Old May 22, 2014 | 06:58 AM
Black3sr's Avatar
Give me your Email addy and I can send the PDF document from the manual for the removal.
Bill
Old May 27, 2014 | 05:32 AM
Chaza's Avatar
Thanks Bill... my e-mail is chaza.wick@gmail.com
Old Jul 8, 2014 | 11:46 PM
ehaboy's Avatar
Bill
can you send me a copy as well? I was trying to change spark plug, but havn't figure out how. pennylast123@gmail.com
Old Aug 25, 2014 | 11:26 PM
hspatz's Avatar
This is easy if you remove the air box, plastic manifold, valve cover, etc. and do a valve adjustment at same time--a good thing to do at the mileage you need to replace spark plugs. No need to touch plastic cowl, if you do this--plenty of room.
justanewbie
Feb 1, 2020 05:12 PM
GE82010
Apr 25, 2018 11:47 PM
demouser
Oct 15, 2017 05:37 PM
CarbonCorsa
Oct 22, 2014 04:00 PM
manxman
23
Sep 28, 2011 03:57 PM
